I just installed one on the passenger side of my 16' passenger wagon XLT with manual seats. It states in the web site that it won't work on seats that have the heater under them but it fit on mine and so far no problems. They do not supply instructions.
Step 1: Unbolt the 4 seat bots sliding the seat back and forth to make room. (T40 I believe)
Step 2: Disconnect the electrical connector at the under-seat junction and remove the seat.
Step 3: Take the electrical connector appart and feed the wires through the hole in the center of the swivel. Take a picture of the back side of the connector to remember where your wires go. Pull the red tabs out completely and use a small pic to slide in the backside and hold the retention clip down while you slide the wires out. Feed them through the hole and reassemble in reverse.
Step 4: Lift the lever and turn the swivel 1/8th of a turn to make access to the bolt holes. Set the base down. You will need a spacer on the rear bolts between the adapter and the van. This is both to make it level and to prevent crushing the under-seat heater. I just happened to have some steel spacers of exactly the right dimensions laying around. Bolt the swivel down. (I used the original seat bolts as they seemed a little beefier.
Step 5: The steel handle on the back of the seat for attaching a kids car-seat will have to be cut or bent. I bent mine down by holding the base of it with a large pair of channel locks and using a pry-bar working one side and then the other.
Step 6. Set the seat on the swivel and bolt it down starting with the front 2 bolts. Make sure your electrical wire/connector is behind the crossbar that connects the right and left seat adjustment hooks. The seat comes with 2 sets of 4 bolts with one set being longer than the other, use the shorter set.
Start to finish it could be done in less than an hour if you have the tools on hand and something to use as spacers. I'll update you when its been in for a while to let you know if there have been any issues.
