Hi!
I'm planning on mounting two Solaria PowerXT-400R-PM panels to my 2020 EL Transit. Each is roughly 64 3/4" x 47 1/2". The panel's long sides would span the width of the roof with their ends hanging over the middle of the 1.5" wide roof edge grooves. I would mount them directly to the roof with 1/8" aluminum Z brackets fabricated from two pieces of aluminum angle, similar to how Orton did his: Solar System | Orton Travel Transit
The panels I've seen are elevated an inch or so from the roof, I assume to allow air entry for cooling. But since the roof is crowned and I am mounting across the width, couldn't I mount the center of the panel frame directly to the center of the roof? Only a few inches away the gap would reappear and grow to 2 or 3 inches at the roof sides.
While reading about making a wind fairing for the front, Test of fairings on solar panels to reduce drag I also saw that it may help a lot to make a rear exit fairing as well as side fairings to prevent drag from the underside of the panel. This wouldn't be hard to do but I'm concerned about restricting cooling air flow when I'm parked. I could also but the panels together to save space and prevent drag, but am concerned again about heat dissipation.
Thoughts?
Thoughts?
