I wanted to share an amazing piece of tech for those of you with Chinese diesel heaters or for those of you planning to install one. I was initially tipped off to this by ForestyForest's youtube channel and ordered one for my install.
A very, very smart gentleman named James Browning-Smith out of the UK is building silent diesel pumps. These can be mounted inside or outside and in any orientation. They are also agnostic to fuel type. You can run kerosene without fear of wearing out your pump. He builds these one at a time by hand, so keep that in mind when ordering. If they are mounted touching a hard surface, you can hear a tiny, tiny sound, but if mounted on some foam insulation, it is truly silent.
I received an early iteration and unfortunately developed a siphon which flooded my heater while parked. He has a new design with an anti-siphon solenoid shutoff, though.
Though the pump itself is incredible, the after purchase support from James is the best reason to buy one. His knowledge of these heaters is absolutely encyclopedic. He responds to emails almost instantly. I have probably exchanged almost 80 emails with him, mostly because of my own ineptitude. With his recommended settings, I am seeing 3 ppm of CO with a meter directly next to the tailpipe. I would bet that less than 0.01% of Espars are running that clean.
Anyway, give some business to a very smart guy/small manufacturer if you have one of these heaters.
You can reach James at: [email protected]
A photo of my install and the pump:
