From the Faroutride site:
I use these without tape or pipe dope.I am assuming that since the Shurflo instruction make no reference to teflon tape or pipe dope, the pump fittings do not need either to seal properly. Can anyone confirm this?
Same. No tape or dope or anything. They seem to seal quite well - but only on the appropriate pump or filter. It seems the angle of the "cup" on the male side makes a great seal. I tried using them for other stuff and it was not so successful.I use these without tape or pipe dope.
No, I'm talking about the fitting to pump connection, not the hose to the fitting.Barbed hose fittings usually just rely on a tight clamp, If that is what you are asking.
