1 - 6 of 6 Posts
I've been looking in Forscan to see if I can make the engine start in Eco mode. I almost never need the extra power of the ecoboost engine driving around town, and would prefer to start in Eco mode rather than having to remember to turn it on everytime I start the engine.
Anyone know if this is possible in Forscan and where to find it / what it is named?
Changing the mode is done by pushing a button. Just like deactivating the auto start/stop. So it is certainly possible. Dont know about modifying the firmware, but a small timer device and a relay, just like i did for the auto start/stop will work......
2020 148 HR AWD
I kind of wish this was factory configurable, without Forscan, but for those of us with AWD which supposedly locks into 2wd when in Eco mode, it could be an issue that Ford didn’t want to deal with. Angry customers complaining that they got stuck in slippery conditions, or worse, in their AWD vans. But honestly, I haven’t noticed a repeatable fuel economy improvement with Eco mode ... have others seen anything consistently?
Discussion Starter · #4 ·
I've been getting 19mpg around LA with Eco consistently enabled and 16mpg (or less if I really let it spool up) with it off. That's based on about 6 tanks of data using the numbers reported in the dash though, and not a very scientific measurement.
Discussion Starter · #5 ·
Except the engine mode cycles through four options. So you'd have to make it "push" the button twice to get it to eco mode and if one of the pushes didn't register it wouldn't change right.
This really seems like it should be a setting in the ECU and Forscan should be able to set it. Maybe it isn't there but I thought I'd ask to see if anyone else has found it.
1 - 6 of 6 Posts
