1 - 2 of 2 Posts
Is there anything difficult about replacing the wider of the two belts? Looks pretty straight forward from the top.
No speculation, please. Only comment if you've done it. That, or a reliable YouTube video. I can't go through them at the moment.
Discussion Starter #2
Well, success. 45 minutes to change the main serpentine belt in a Sobeys parking lot with only a 15mm wrench at -12°C. I thank the designers for not making it stupid. The spring tensioner pulley and bolt are obscured from view from the top, but trust me - they're there. It would be much easier with a cooler engine (one burn, back of right hand), and getting the belt around the crank pulley may have been easier from the bottom (but I wasn't to be laying in the slush.) I'm also lucky the wrench is the same size as the oil drain plug, otherwise I wouldn't have one.
1 - 2 of 2 Posts
