I will be installing a few 12V "cigarette lighter" style sockets for utility use. For example, laptop chargers and CPAP machines that use 12V car adapters. In the past I've had trouble with these sockets being too loose. Please reply if you know a brand or model that seems better than the rest. Ideally with quick connect tabs on the back.
A Powerwerx plut with a Powerwerx adapter is also a possibility Powerwerx to cigarette lighter female adapter It's another cable to keep handy, but with that adapter if the connection gets loose it's possible to just tape the two cigarette lighter components together.
I'll also have some USB-A sockets. In case you are interested, the Blue Sea System one are a bit pricey, but only have a 1 mA parasitic draw, so I'm planning to just leave them switched on most of the time 4.8 amp Blue Sea System charging port
I'm sure that others have had this question before, but I was not able to locate a post specifically on this.
