1 - 11 of 11 Posts
Has anyone asked for,or do we have a way of doing a search for data
Things look like they are growing fast, now that you can buy them
One thing I found annoying was having to select to search through google or the forum, older versions of forums had a forum search as the default search option which helped. Now im used to it, both can be useful
are you sure? it auto defaulted forum search for me... although i use the one in the navigation bar, not sure if the lower search bar is set up different....
edit: its not, for me at least....
Discussion Starter #5
Thats what I found
OK, this is showing me/us its not 100% working easy (Search)
Discussion Starter #7
I am just geting to see how it set up.
Is it just for internal forum stuff, or can I search for anything?
every forum "search" is a little different
I have found some very interesting stuff by others here
Thats what I thought since i always see the google sign in place by default but it's probably possible you can change the default settings
Administrator
In the search box, do you see the drop down arrow located to the right of the Google logo? Click that button to designate whether you want to use Google search or the internal forum search.
Two options so you can search the way you prefer to search.
im not even sure why there is the option for a built in google search
pretty much every browser has google search built into the browser.
I guess it can help since the VB search for example doesn't allow less than 4 characters, and that it could be more accurate.
1 - 11 of 11 Posts
