You may have better luck finding someone with experience with them on a solar power forum. The one I use is run by Northern Arizona Wind & Sun, who sells both models.
http://forum.solar-electric.com/index.php
I have a 1500W PST model but it's the previous generation. Worked fine for my needs at the time (I had a 12V bank in the house, have since upgraded it to 48V) and am debating installing it in the Transit. Not sure I'll need it yet though...
From a brief read of the SA web page it sounds like that line has been built more like a "real" off-grid house inverter. The PST series is more of the "turn it on when you need to use it" type inverter. It doesn't go to sleep automatically, has a relatively high idle current, stuff like that. Also the SA line looks to be designed to handle poor power factor (reactive) loads better. That may or may not be very useful for you, depends on what you intend to power with it. I have so far not found much I'd want to run that's too bad power-factor wise. I'm not sure how a microwave does though, haven't put my Kill-A-Watt meter on one to measure yet.
One spec difference that could be very helpful is the surge rating. The PST series is kind of pointless - mine was rated 1/2 cycle (1/120th of a second!) which is useless really so anything I want to power with it must come in below 1500W - thus why I got it in the first place, so my fridge would start. It had a 1200W or so surge on startup that would last several seconds. The SA's 3 second rating is more reasonable. My favorite inverter in this regard is the Morningstar SureSine. Only a 300W inverter but can handle a 600W load - for 15 minutes!
