I'm installing a Maxxair 7500K Deluxe and I'm about half way through. I'm using one of the Impact 3D (Hein) adapters and I'm about to add the fan roof flange onto the adapter with butyl seal tape (if I can get a break in the Seattle rain) but I'm trying to figure out if I can use the screws that came with the fan since they look like they'd go through the adapter into the sheet metal. Do I screw into the sheet metal (I'm inclined not to)? Do I need shorter screws? I'm wondering what opinions are out there.
For the curious, I'm mostly following the Moreys in Transit (http://moreysintransit.com/install-roof-fan-van/) approach with the only difference being that I didn't believe that I could make the jig saw cuts from the top of the van on a ladder (arms to short or something) and from the inside the jig saw hangs up on the ribs so I cut the square out with an angle grinder.
