I look forward to responses as I was considering JUST factorty rear air to cool down during a HOT day, and a MaxxAir Fan for night. Would anyone comment how long you can run a MAXXfan on the dual factory OEM batteries?
You describe it as though you wouldn't have any house-battery setup except for air-conditioning. If that's the case, easy call: go with the ~$900 and give it a try; worst case, $900 wasted. If you're going to have house batteries, inverter, etc... then it's a question of how that will change to accommodate A/C - and it can be a BIG difference depending on the answer to that question.Soon I will order a Transit high roof with the long wheel base. I am thinking about the relative merits of the factory ~$900 rear air conditioner option vs the non-factory ~$5000 roof mounted unit+battery+inverter combo option. I scrolled through about two dozen threads and did not find a good evaluation of the rear factory air unit. I see some people saying it works less well when the engine is idling. My question is this: If I park this van in the hot summer heat and run the engine to run the front and rear air conditioner, will it keep my van cool while it is parked? I will have a white van and I will put in good thermal insulation. Please share your experiences with the factory rear air conditioner option. If it is not going to keep my well insulated white high roof long van cool while parked, I think I should go for the roof mounted one. Another question: If the factory air in the rear is sufficient, why do people spend $5000 on battey powered air conditioners?
Get it. The cost is so low it's worth it. I think the sprinter rear a/c option is like $7000 - $8000. You can keep the rear cool while driving, and avoid having to run your inverter and house a/c. Fewer hours put on the house a/c will hep it last longer. Also, when driving, you'll often be charging your house batteries. That will go faster without a large a/c load.Soon I will order a Transit high roof with the long wheel base. I am thinking about the relative merits of the factory ~$900 rear air conditioner option vs the non-factory ~$5000 roof mounted unit+battery+inverter combo option. I scrolled through about two dozen threads and did not find a good evaluation of the rear factory air unit. I see some people saying it works less well when the engine is idling. My question is this: If I park this van in the hot summer heat and run the engine to run the front and rear air conditioner, will it keep my van cool while it is parked? I will have a white van and I will put in good thermal insulation. Please share your experiences with the factory rear air conditioner option. If it is not going to keep my well insulated white high roof long van cool while parked, I think I should go for the roof mounted one. Another question: If the factory air in the rear is sufficient, why do people spend $5000 on battey powered air conditioners?
My Ford E-350 OEM A/C works great at cooling van, but as others have stated, requires van engine to idle which isn’t possible or practical much of the time. A Transit engine-driven air conditioner would have same limitations (except for lower fuel consumption during idling).If the factory air in the rear is sufficient, why do people spend $5000 on battey powered air conditioners?
Why tow a generator. We put an onan 4000 watt generator under the van.If you already will need auxiliary power in the van for other reasons, then the cost of implementing a somewhat larger system capable of powering the air conditioner isn't necessarily too much of an issue.
For instance, the typical power system that I supply / ship to customers is a 2 kW inverter + 4 LiFe batteries + related stuff to operate it, and I have built what is essentially 2x this system for a sprinter that runs the a/c and full cooking simultaneously. The smaller version can run what you are talking about for 3 - 4 hrs engine off.
In my mind, one of the big reasons for going down this path is that you can easily pre cool the van without the engine being on, as well as keep it cool while shopping or working in it.
It of course depends on your climate, but in this area, we get so much sunlight that children can't touch seat belts or seats of pretty much any vehicle for at least 15 minutes after the engine is started / AC running hard.
This was one of the big motivators (along with wanting a portable office) for the development of power systems like this.
It isn't cheap to go down this path though - it can be close to $15K (total including the a/c) if you hire it all out to be installed for something that is rugged enough for regular use.
Another path that is lower cost would be to use a generator in a small enclosed trailer that you pull behind.
____
My main hesitancy about running the van engine in idle mode for long periods of time would be the potential for substantial maintenance. Normally that is just a cost question, but now - it is both a cost and parts availability question.
4,000-Watt generator seems large to me for a van, but a great option to evaluate versus extended idling. Most factory gasoline vans that have Onan go with smaller and lighter 2800-Watt model which should be powerful enough for most owners. The newest 2800i (inverter model) is much more fuel efficient at partial load, like would be required to power air conditioners in 1,000~1,500 Watt range.Why tow a generator. We put an onan 4000 watt generator under the van.
Mostly for the noise inside the van, but also as a way to deal retain ground clearance.Why tow a generator. We put an onan 4000 watt generator under the van.
That is why I suggest to people to use at least a 3000 size generator. The fuel tank on the smaller ones just isn't large enough for air conditioner or heavier uses.4,000-Watt generator seems large to me for a van, but a great option to evaluate versus extended idling. Most factory gasoline vans that have Onan go with smaller and lighter 2800-Watt model which should be powerful enough for most owners. The newest 2800i (inverter model) is much more fuel efficient at partial load, like would be required to power air conditioners in 1,000~1,500 Watt range.
Presently using and having to haul around portable inverter generator and fuel containers makes me miss the built-in Onan in previous RV. It’s so much more convenient. Having said that, cost to add a new 2800i Onan isn’t much cheaper than adding extra battery and inverter capacity (assuming van would have some lithium battery and inverter anyway in addition to generator).
I chose my 2200/1800 Watt portable inverter generator in part because it had a larger 1.3 gallon fuel tank, which allows it to run around 10 hours overnight. Granted, I only power 5,000 BTU/hr A/C. The 10+ hours is good enough to prevent having to refuel in middle of night, though it is not as “convenient” as a built-in generator that takes fuel from vehicle’s tank. Similar portable generators like Honda only had 0.95 gallon fuel tanks, and I wasn’t sure they would run through the night (though possible if more fuel efficient).That is why I suggest to people to use at least a 3000 size generator. The fuel tank on the smaller ones just isn't large enough for air conditioner or heavier uses.
A 3000 is also quieter than a 2000 for any load greater than 1000 watts.
It’s actually pretty quiet. As far as clearance someone mentioned. The rear differential ans hitch are lower. So they would bottom out before the generator.Mostly for the noise inside the van, but also as a way to deal retain ground clearance.
I would enjoy seeing some photos of your installation.
We put a 4000watt. Instead of the 2800i so that we could run the ac in the van and the ac off our tow Rv both off the same generator. (With soft starts on both). Works great.That is why I suggest to people to use at least a 3000 size generator. The fuel tank on the smaller ones just isn't large enough for air conditioner or heavier uses.
