Sounds like an awesome trip! Thanx for the feedback!
Not to factory specs. The dual rear wheel vans are very different, including heavier duty axle, spring centers that are closer and therefore mounted at different location, and the body's wheel wells are wider to accommodate the inner wheels being much closer together........cut.......
Does anyone know if you can put dual wheels on a van that came from the factory with single rear wheels? also, would sway bars help and does anyone know where to find them?
Thanks for the detailed write up, very helpful.My wife and I just got back from an 8 day road trip in our New Transit. I have the 3500 extended high roof with the diesel motor.
[snip]
My only complaint is the high roof is top heavy and it catches wind, especially in the open areas and behind 18 wheelers in the wind wash.
[snip]
Overall I would give the van a 9 out of 10.![]()
An empty van typically has a lower center of gravity than a loaded van. The added load's CG is higher than the empty van's, so the combined is almost always higher than the empty van. What is different about this application?......cut......
Right now, with the high roof van having a high center of wind resistance (looking at the side of the van), and with the unloaded van's center of gravity/weight being the highest it is ever going to be (and higher than your van's engineered design for loaded use), you are asking a lot for this "sail" NOT to react to lateral wind loads. There is no "sailboat keel" to keep the thing grounded, in a sense.
......cut.......
Great Idea, since I would only need 4 that might be a practical way to fix this.Wider tires will help with wind thats what i did to my SPRINTER and the wind problem was gone!!!
3.31what is your gearing![]()
In my opinion, your van will behave much differently when you complete the interior work you have mentioned in other threads, and have heavy material loaded on the floor. This will not only increase the van's gross weight, but it will also lower your center of gravity to be much closer to the ground.
When you load the van with its designed weight, placed closer to the floor, I think you will find that side winds have much less of an impact than during your recent trip.
To test this out, take whatever heavy material you want to use temporarily, and load up the van with 1-2,000 pounds of material held low to the floor. I think you will find quite a change.
All the Econoline vans I have owned required loading up (if empty of regular loads) to act right, including temporary sand in the rear to help with traction during the winter snows. It made a big difference . . .
Good luck, and thanks again for the review.
Peter
PS -- Did you ever order the interior paneling you mentioned?
http://www.fordtransitusaforum.com/interior/3450-long-walls.html#post44610[/QUOTE
I have not ordered a wall kit yet. I like one I have found from a company called Fleet legends or something like that, shipping and all is around 3000 grand. I found several sites that put in a fully carpeted wall and ceiling liner in the econolines but have not made the kit for the Transit yet. Cost was a lot less and would suit my tastes better. Still waiting at this point. I installed my etrack for now.
My van does not have a trailer hitch and I may have someone weld a piece of railroad rail underneath to mount the hitch and add weight. This is an older way of adding weight to a pickup for stability and may fix the problems I have as well. thanks for your insight!
3 grand!Thanks for the detailed write up, very helpful.
Peter
3.31 and yes the idel time was for the whole tripWhat gear ratio are you running? Was your idling time accumulative over the entire trip?
