Hi - I finished installing better rear speakers in my 2020 Ford Transit yesterday and thought I'd post a couple pics to help anyone else trying to find the wiring. I did order the 6-speaker package with the van, so it came with (crappy) rear speakers, but in a location in the bottom of the rear doors that will be under the bed platform, so I moved the location to the back of the headliner above our heads (idea stolen from Far Out Ride's helpful blog post).
For the left (driver side) rear speaker, there is harness LK4T-14A333 just inside the rear opening above the wheel well on the driver side:
It comes as a loop with the the two wires closest to the edge of the harness plug as the source from the radio looped to the two wires closest to the middle of the harness plug that go to the speaker in the rear door. When you cut the loop, it disconnects the existing rear speaker, and you can connect the new speaker to the two wires closest to the edge. For the left side, White/Green is the +, Brown/Yellow is the -.
For the right (passenger side) rear speaker, there is a larger harness right at the lower rear-most opening by the back door.
It has a bunch of other wires - but also a similar loop of larger speaker wires like on the other side. Trim the loom down enough to pull out that loop (careful not to cut any of the wires). Similar to other side: It comes as a loop with the the two wires closest to the edge of the harness plug as the source from the radio looped to the two wires closest to the middle of the harness plug that go to the speaker in the rear door. For the right side, Brown/White is the +, and Brown/Blue is the -.
Hope this helps - even with all the helpful posts on rear speakers, it took me a while to figure out where I could patch in!
Headliner speaker success! Or at least once the aftermarket grills arrive, it will be done - I found out some speakers don't come with grills. :-0 Anyway, they sound way better than the factor speakers.
