We received pictures from a customer of the Q-lift. The lift is basically the same lift kit we created back in 2015 for the 2wd Transit. It was called our Terrain kit. We dropped the subframe 2.5" and provided strut spacers for camber correction and a steering shaft extension. The Q-lift is very similar to our old subframe drop kit, they added a front diff drop bracket to make it work with the AWD front CV shafts.
We installed the Terrain kit (subframe drop lift) on our AWD test van and decided it was not going to be worth the effort to make the kit work. The front diff needed to be dropped, but it is attached to the transmission. We had a design for a diff drop spacer, but accessing the diff to install the drop spacer requires the exhaust to be removed, not to mention the entire suspension subframe. We mocked everything up and noticed the front driveshaft was at way too steep of an angle at the transfer-case flange if you drop the diff 2” to match the subframe drop. The upper driveshaft boot was rubbing on itself and the joint was difficult to turn (binding). If you look closely at the Q-lift 2" subframe drop and compare it to the diff drop bracket you will see that the diff is not dropped a full 2” when you compare the bolt hole centers to the subframe spacer. The diff appears to be dropped about 1.25” and slightly rotated forward. This leads us to believe that the front CV axle shafts are still getting close to a bind at full suspension extension and steering lock, especially with a 1” longer B6 strut installed. We now see two longvetivity issues - a front driveshaft that is operating at an extreme angle and the CV axles are getting close to binding. Installation of this kit is very involved and takes many hours to complete. All the steps needed to remove the suspension subframe, exhaust and diff are complicated. The cast iron front diff housing is also cut and modified for the diff drop bracket.
Van Compass decided to go a different route for an AWD lift. Coil lift springs and small strut spacers to correct camber. Much more affordable and way easier to install. So much so that we decided to just sell the 2” Topo kit for all Transits and drop the Terrain kit from our lineup. The Topo kit installed
without the 1” longer B6 strut keeps the front CV axles within the operating range. We are currently working on a 1.5” front lift that will allow the use of B6 struts with no CV bind. Also, a Falcon coil over strut with a top out damper is in the beginning stages of development for the ultimate ride improvement.
Here is what you are getting with the Q-lift for front suspension mods.
Steering shaft extension
Subframe drop pucks:
Drive shaft angle. Can’t see the Transfer case flange well, but
notice the grease slinging out of the upper driveshaft boot and landing on the oil pan.
Front diff drop/rotation – The top bolt flange of the diff casting is cut off. The sheet metal bracket drops and rotates the diff to correct the CV axle shaft angles.
Factory diff shown with the 3rd upper bolt that is cut off the diff housing for the drop bracket.
