1 - 3 of 3 Posts
Changed the PTU oil in my AWD Transit today at 6500 miles. Wanted to do it at 5000 miles but time got away from me. Draining access was EZ with a T50 Torx bit. Ford put in a magnetic drain plug and mine had a good layer of gunk on it. This picture was after I cleaned the plug.
140924
I drained out 24oz of fluid and put in 30oz for a net gain of 6 ounces!
140926
I put some Teflon tape on the threads for the next oil change.
140927
Filling can be a slow process if you don't have MightyVac or it's equivalent to pump the gear oil into the fill port. Or if you are poor and cheap like me, tape a funnel to the passenger side fender and run a line to the fill port.
I'm not a big fan of Motorcraft oils so I replaced the fluid with Red Line 75W-140.
140928
Now I can rest EZ knowing my little PTU is bathing in fresh happy juice. With less than a quart of fluid in the PTU and the heavy weight of the Transit it has to push around, I'll probably change out the oil every 10,000 miles for now on.
Thanks for the write up, i've been thinking about changing mine sooner than later as well. Is the fill port pretty easy to get at too?
Discussion Starter #3
It's not hard to get to or remove the fill plug BUT you likely will want to use a long fill line running to the fill port. A pump capable of moving thick gear oil will speed the process or as I stated a funnel with a long line that runs from outside the vehicle.
1 - 3 of 3 Posts
