Why are you worried about propane?
Should not be a problem if tank is in a sealed enclosure that has a drain hose.
a boat is open at the top and closed at the bottom. Propane gas seeks the lowest point, therefore this situation is bad on a vessel that has no way for the propane to seek a lower point than the hull, whereas alcohol fumes and gas go up so it can vent from the deck and vents in the deck thus preventing the death of the crew of the vessel.Why is alcohol considered so safe? We have an alcohol-burning fireplace insert, and the fuel bottles have warnings all over them about spillage, and how the flames can be invisible, etc. I know that alcohol is used extensively on boats, so it must be okay, I'm just wondering why it's okay.
paul
oh, i see. so alcohol is safer because of venting issues -- not necessarily because of handling issues. thanks!a boat is open at the top and closed at the bottom. Propane gas seeks the lowest point, therefore this situation is bad on a vessel that has no way for the propane to seek a lower point than the hull, whereas alcohol fumes and gas go up so it can vent from the deck and vents in the deck thus preventing the death of the crew of the vessel.
Sounds pretty good. I already use two Mr. BUDDY PROPANE heaters when I want to get in my travel trailer. I have two windows open an inch and a quarter.When my father in law was ordering up his Sprinter conversion recently, a friend who is a local fire chief recommended propane over alcohol due to safety concerns over spilled alcohol and the fact that burning alcohol is basically invisible. That might be being overly cautious, but it's something to consider.
Me, I'm a portable stove and propane canister guy. A good solution if you're not doing a ton of camping. I get several weekends out of one little canister.
JP
i'm assuming you mean the gasoline-powered one? yeah, that seems like a good solution if you don't want propane. people seem to say they're really loud -- i'd love to hear one in person before i'd pull the trigger on that. (on the other hand -- "warm enough? priceless...")For heat, I'm going with an Espar airtronic system.
