Left-right weight distribution
In my van, the kayak location is a limiting factor. The floor space on right of van must remain clear, thus, that is not a good location for bulky-heavy items like cabinets, water, batteries. The only "useful" floor space would be ahead of and behind the wheel wells.
So, the only thing that has made sense is to put the bed on the right side. I expect to make it hinged on the wall, so that it can be folded out of the way. It may have legs or chains for support. It will probably have the mattress on all the time. In memory foam or latex, the mattress might be 40 lbs.
I figure to have a base cabinet along the left wall -- maybe full height in the back half. I really only want simple jerry cans for water storage -- put, say, three for drinking water under the counter, with easy access door, and a 4th for grey water from a simple sink. Probably set up a 12v pump, with feed tube that can be swapped between cans. MOST of the time, the water cans would be empty.
It looks like the cabinet just behind driver seat is the logical position for house batteries, so that's more weight on the left side, and it would be carried all the time.
If it could help my weight distribution, I would consider a chassis mounted, dedicated water tank. Unfortunately, the right chassis space does not look as good as the left, for clear space and mounting options. BUT, maybe someone has ideas on appropriate tank and mounting for that right side space. And, I'm not going to have the elevated floor that some install in the high roof Transits. So, water line would have to run... under the cargo box? (I don't live or travel in extreme cold.) Pex through wall and ceiling space? Or, maybe just along the front edge of whatever floor I put in, where it would have some protection?
Maybe I'm missing something that would help. Or, maybe I'm not going to have enough weight bias to really matter in a vehicle with such high weight capacity.
