It was time for the plywood to be added to the Poly-Iso insulation panels on the floor of the cargo van. I use the paper templates that I made previously to remove the cut-outs from the sheets of plywood and add dadoes to form an interlocking system.
Although I ended up sealing the plywood at a later stage, this is the time to get your Shellac, varnish or polyurethane and a couple of brushes and protect the plywood against moisture.
As always, I have detailed every step on the Project’s Page, and added lots of pictures and videos.
Comments are welcome!
Van Williams
Van Williams
Save
