1 - 9 of 9 Posts
Happy Sunday y'all. I removed all of the tracks that were bolted to the floor of my 2017 Passenger wagon and now I need to cover the holes where the bolts once were. Is it crazy/stupid to fill the holes as best I can with sealant and cover them with Rustoleum-coated nickels? Trying to work with what I've got to save some money and I've got a LOT of coins lying around. Thoughts?
Welcome to the forum! Apparently, you missed the memo about a national coin shortage. ;)
Kidding...I'm not sure about nickels, but you can probably find rubber plugs in various sizes at your local Ace (or similar) hardware. You can add a little silicone to the lip, and pop them in the holes. Just another option to check out.
I don't think they'd need any Rustoleum, they're already rustproof
After removing the rails, I used about 10 of the threaded holes to mount plywood for the floor. The other empty holes were plugged with a bolt before laying the plywood down. Problem solved. Floor is solid - good foundation for the rest of the build.
1 - 9 of 9 Posts
