Probably a loose connection. Not uncommon on new vehicles. If you can pull the light unit out that is the most likely place to find it.
Thanks for the suggestion. You were right on. I pulled the unit out from the ceiling and found that the connection is very flaky and was bouncing in and out. Taking it back to the dealership next week.Probably a loose connection. Not uncommon on new vehicles. If you can pull the light unit out that is the most likely place to find it.
