I've only found a "creep up to the object" sensor so far:is there even a sensor made that does this while driving at speed?
I seen sensors that measure clearance, but those are for drivers who creep up to the object, not blindly driving around.
I like the idea but I'd be wary of lasering someone in the eyes.I have a different solution in mind for this that I want to try.
I want to make a visual guide with a laser line mounted on the roof rack. They have all kinds of laser line flashlights online that could be adapted. I will mount it on the highest point of the vehicle and have a remote switch to use it as needed.
I know it's not a perfect solution and assumes you always pay attention and it's not super accurate when you are on a slope but it would be meant for fitting in tight places - so usually slow driving, parking, avoiding branches when driving at night in a forest and such. I am even considering 3 lines to project general outline of the vehicle forward - height and width. I think it will also just be a really cool gadget to play with![]()
Right. It would not be meant to be on while driving on a highway or street. Just for instances when approaching obstacles that you can already see up close - like a tunnel, garage opening, old viaduct or covered bridge, or a tree branch.I like the idea but I'd be wary of lasering someone in the eyes.
You could try one of these:If there was a height sensor available I would definitely install it. It doesn't seem it would be difficult to make one - Just a proximity sensor with clipping planes maybe.
Hmmm. This looks like a home electronics thing. Max distance 1.5m - (5ft), and you would have to weather seal it somehow.You could try one of these:
They work really well, although I'm not sure the range would be adequate for your goal.![]()
Amazon.com: Laser Sensor Receiver Module Kit Laser Sensor Module Transmitter Module for Arduino AVR PIC STM32 : Electronics
Buy Laser Sensor Receiver Module Kit Laser Sensor Module Transmitter Module for Arduino AVR PIC STM32: Computer Components - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I like this idea and have thought that I would like one that buzzes inside when it touches something. Anyone done something like that?Mount a cheap antenna that's 2" taller when mounted than the highest projection on the roof.
You will hear it drag/scrape if clearance is to low before you hit something important.
