1 - 5 of 5 Posts
Hey all -
I think I might be missing a piece of hardware. Take a look at this seat base and rail, which I bought sight unseen and just received.
Can anyone show/tell me how the rear part of a seat (this one's a single) is meant to attach to the rail? Am I missing a piece?
The single does not have the clip the other seats have- the rear of it bolts down.
That rail you show is not for a single seat if it has two loops.
Very helpful, thanks! This is indeed a single seat and a rail that has two clips/loops.
So does the correct rail have a female threaded part to accept a bolt that goes through the seat base?
I bought the items from NorCalVans. With any luck they'll send the right rails up.
Yes the single seat rails have a threaded part the rear of the seat bolts into.
If they send you the right rails make sure you get the bolts too...they are high strength metric.
Discussion Starter · #5 ·
Just thought I'd follow up and say that Nor-Cal Vans was totally responsive, found the correct rails and bolts, and is shipping them to me right away.
If you're in the market for some OEM seats, I recommend getting in touch with them. http://www.nor-calvans.com
Budsky, thanks again for helping me sort this out!
1 - 5 of 5 Posts
