21 - 40 of 51 Posts
Just talked to Wheel Pros, a major distributor of aftermarket wheels all over the USA and they do not show any available wheels for the 2020 Transit AWD model and are NOT going to be offering any in their NEW 2020 catalogue.
Administrator
2018 T350HD Dual Sliders
I'm not surprised. Any new products in the 2020 catalogue will have been under development 8-14 months ago. You need to time to measure, design, prototype, test, manufacture, distribute, advertise, etc. Given that the 2020's are just now hitting the dealer lots it's no surprise that some wheel company doesn't yet have wheels for it.
Looks like this is the forged aluminum wheel. It looks a little different from the pics in my order guide, I suppose it's just missing some kind of hub cap.
source:
Crap, I appear to have fallen in love with yet another vehicle where owning a separate, dedicated set of snow tires/wheels is ridiculously expensive, due to the wheel portion of the price.
I was hoping there would be cheap(ish) steelies available.
Maybe something will change by next fall......
Administrator
Don't worry, there will be. There are a lot of people who will get their new 2020 Transit AWD's and as soon as an aftermarket wheel is available they will buy them with larger tires, and the OEM ones will be for sale on here and/or eBay.
A lot of the Class B converters will be ordering the Cab chassis and then putting Hunter or CWS wheels on, and the steel takeoffs will also be on eBay.
source:
Are there no center caps on the forged aluminum wheels or do they use the same ones as the standard AWD wheels? Would they be swapable?
I would be satisfied (for now) if I could find a different center cap in black and then painting/powder/plastidip standard wheels.
Anyone have any ideas on where to find a 6x180 center cap? The google hasn’t led me anywhere good yet
2020 Cargo T-350 LWB HR EB on order...
Discussion Starter #29
If you look at the 2020 Transit build-your-own page on Ford’s website, the image now updates with the correct wheels when you add AWD. Steel wheels are standard. Forged aluminum wheels are optional.
That dealer left off the center caps for the Forged Aluminum wheel. You should be able to get the lugs nuts for the Aluminum wheel and then order the cap for that wheel so it would clip over the lug nuts. Not sure that the lug nuts for the Argent Steel wheel has the correct lug nuts to hold the chrome center cap from the Forged Aluminum wheel.
Please check my logic as I'm considering the Ultra Hunter option for the 2020 AWD I have on order. Given that wheel is 6" wide it would be prudent to replace the 235 tire with a 225. My back of the envelope calculation indicates (in theory) I'd gain 1.8 mm between the tire and frame and lose the same amount between the tire and fender. Sure seems like that wouldn't pose any issue.
Discussion Starter #33
Please check my logic...
Could you share the details of your logic? Did you account for the difference in offset?
Yes and no. Yes in that I did account for offset, no in that I did it wrong... The logic is as follows:
1. The difference in offset moves the wheel to the outside by 116.8 - 110 = 6.8 mm
2. The difference in tire increases the gap on either side of the tire by (235 - 225)/2 = 5 mm
3. The new gap on the inside of the tire is then 6.8 + 5 = 11.8 mm
4. The new gap on the outside of the tires is then 6.8 - 5 = 1.8 mm
Discussion Starter #35
Thanks! That makes sense to me.
205/75x16. Another common size with plenty of load E options (eye roll). Come on Ford. Just come out with 245/75x16 capability...at least. at least on 250’s & SRW 350’s. The government isn’t going to come down on you.
Most Transit buyers are replacing the original tires with other tread patterns and sizes once they get their Transit or when they get close to the 40,000 mile range when the original tires have been worn down to their limits.
I replaced my tires at the 50,000 range with the Michelin 245/75-16 LTX Load range E tire. They fill out the wheel well a lot better with a slight rub at full lockdown turning. They work well especially if you do a lot of highway driving with a smooth and quiet ride.
Was checking the Tirerack site to see if they listed wheels for the 2020 AWD. Happy to see they had finally added 2020, but then noticed that the 12 wheels displayed were all 5 lug. Wonder what's going on. They could have some pretty disappointed buyers if they weren't paying attention.
Some companies that are mostly into selling tires may get messed up if they do not know about the AWD wheels being different that the RWD. And just because the DRW model has the 6 lug wheels does not mean they will work on the AWD models.
I am sure we will see this happen when someone unknowingly will sell some of the DRW wheels to someone with a AWD and they figure this out with mounting them and causing damage to their vehicle.
Administrator
I was just looking at the latest Body Builders Layout Book for the 2020 Transit and came across this line in the section entitled "What's new".
Increased AWD DRW rear track
New wheels for AWD/DRW are not interchangeable
Edit:
Did a little more reading. The rear track on the AWD DRW is 1.25" wider than the AWD SRW.
21 - 40 of 51 Posts
