Brand new, new used 16 GALLON TRANSIT VAN UNDERCARRIAGE WATER TANK.
Save on shipping and pick up local. I did open box and this tank is very well made.
Can also add 12v Falcon tank heating pad for $20 (paid $35)
Note - Pictures are direct from website.
From Website:
Fits Transit Van undercarriage Passenger side slider door area. Tank will also fit Driver side.
** Does NOT Fit Transit 130 Wheel Base **
* Does NOT Fit Transit with Factory Running Boards*
Tank can be used for fresh or grey water 16 Gallon Tank Tank is designed for non pressurised system.
Needs to be vented.
Overall dimensions: 48″L x 8.5″H x 13″W.
BPA Free, food grade polyethylene plastic.
Tank has (1) 1.5″ NPT port and (2) 1/2″ NPT ports on end that will face the rear of van.
*(3) Stainless steel Brackets, Stainless steel hardware, and rivnuts included. Requires drilling of (3) new holes for 3/8" rivnuts near pinch weld, enlarging (2) hexagonal holes on frame and using (1) factory bolt for exhaust hanger location.
This will require a rivnut tool.
