Let me start out by saying "I'm a yard sale guy"....I collect "stuff".....hardware, tools, building material, and anything else I might be needing "someday". That's a huge help for conversion work and saves $$$ too. I'm not a cheap-skate.....but I am thrifty.
Started with the floor, 3/4" red oak plywood, 2 coats of the old oil-based polyurethane on both sides. I installed it right on top of the factory mat and side door sill. The center isle is open so as not to take away any headroom and will have a thin piece of carpet, easy to drag outside and clean. That piece of masking tape on the floor is a marker for the plumb-bob....necessary to jack one side of the van to get level....creates a very accurate guide to get the cabinet straight.
Ahh, the A/C cabinet, that was a challenge, had to be built-in-place. The 40/ door and the /60 door have different profiles....another challenge. I spent a whole day working on a small slider to close the gap....it got too complicated...I kept thinking it would be easier to stuff a rag in it. And so, I now have this piece of aerocel foam, just waiting for a snip and cut. The 5,000 btu unit works good, but needs hot weather to find out how well. I had to disassemble and drill drain holes in the bottom and will use a pan underneath. The 120v fan I can turn to pull air in or out.....I also have some 12v fans to experiment with. Please don't laugh, the turn-buckle is necessary because the /60 door will not latch by itself. My first idea was a barrel-bolt, this was much easier.
More photos to come as the build continues.
