Has anyone gone with the new Espar B4L-AM3 heater that operates up to 18000’? I can only find them at Heatso. Supposed to be more user friendly with plug and play wiring and less finicky fuel hookup?
I had a very different experience with Heatso, so take it as you will.Has anyone gone with the new Espar B4L-AM3 heater that operates up to 18000’? I can only find them at Heatso. Supposed to be more user friendly with plug and play wiring and less finicky fuel hookup?
Thanks for the input! I don't understand why I cant find any other vendor that sells this new model. Even the Colorado upfitters that answer their phones don't know about it. I'm hesitant to purchase it without knowing someone has run it with success.I would be VERY cautious of buying from Heatso. I did and had to rewire my harness and the US rep for Esperbacher told me to not buy from them and to spread the word. We worked through the issues with my B4( i needed a new fuel pump and a new ECU with the current software) and it has served me well ever since.
I have... not sure who you were talking to. I sent an email earlier today since we were talking about this. I will update when he replies.Have you reached out directly to Espar of Michigan and spoken to Ray? He may have some insights on U.S. availability
Sorry for chuckling... I know you're not crazy or wrong; you and others have done the installs as well as anyone else.Gregoryx
I know you chime in about your perfect Espar system often. It is appreciated.
What you need to understand is that you aren't helping by making us feel like we are crazy, wrong, or unlucky. I've had my system gone through a half dozen times at this point.
It isn't like 1% of us with constant issues with these units. It is much higher than that. My contact said closer to 1/3 of folks with Transits with this system are dealing with the issues that seem to have no instant solution.
I've gotten comments from people enough that I park away from folks and with the exhaust pointed away so no one else needs to hear it.
Interesting on the noise. Imma have to listen more carefully on startup. Curious.@gregoryx Mine for the most part is quiet but sometimes when it starts up the fuel pump makes a ticking sound pulling fuel. I bought it from heatso which people say don't do. I also didn't install any pickup tube and people said it wouldn't work right. I've used my heater more than most in harsh conditions for days at altitude with zero issues.![]()
There's some additional mystery problems. There is at least one person on here who spent a bunch of time with the US Espar guy resulting in replacing parts and/or firmware to eventually get it working (IIRC). There's some additional weirdness that happens - witness those who have NO problems even at elevation with the Ford pickup. Then others with the Espar pickup and issues - though that /seems/ less common.What about getting the heater from Heatso, and then replacing the fuel line and filter with U.S. parts? Seems like the fuel lines are the only issue with European installation kit
Do you /want/ a 2kW version instead of 4kW? I thought the idea of running full-blast had been discredited and the 4kW was preferred at this point. 🤔I have the Webasto Air Top 2000 STC and I also never hear the pump. When the heater is on I do hear the exhaust, but I feel it isn't very loud. Hard to describe....like the sound of queit jet flying over you way up in the sky, or quieter.
As far as the pump, I never hear it, inside or out. I did drop the tank to install the pickup tube that came with the kit but I doubt that matters.
Final point. I did hear back from Ray at Espar. He said he was hoping for July for the new 2kw gasoline model.
If I can fit it under the passenger seat, I guess I would go with the 4kw. I am not building a van right now so I am not really considering which one. I am really missing the building process though. I may decide to sell just to build again. Problem is, I love using it too darn much to be without! But, I digress.Do you /want/ a 2kW version instead of 4kW? I thought the idea of running full-blast had been discredited and the 4kW was preferred at this point. 🤔
I forget where I saw it it someone posted a unit from Heatso and it said on the label “no warranty if sold outside the EU”. I spoke to a builder who got burned, no pun intended, by ordering from Heatso when having an issue.What about getting the heater from Heatso, and then replacing the fuel line and filter with U.S. parts? Seems like the fuel lines are the only issue with European installation kit
