1 - 20 of 42 Posts
Early in my conversion I was overwhelmed with the enormity of what I was undertaking, and overlooked a few critical details.
Chief among these was covering over all of the factory ground points with wood. All of them.
I could go back and dig one or two out, but it'd take some doing -- and I'm not that interested in doing that if it can be avoided. They're really buried.
I've seen in pics of others' builds that some people have mounted a busbar to wood, and terminated all of their loads into that busbar.
I never quite understood this, and now I can't find any pics to scrutinize them in detail.
So -- at last -- my question.
If I drill a hole in my frame, under the van, and create a ground point there, and then run an appropriately sized wire up through the wall and connect it to my negative busbar which is mounted directly to a wood surface, will that work to ground my loads?
All positive loads terminate in a Blue Sea 12 circuit fuse block.
Thanks.
One of my rules I ended up with over the years is to never bury anything , maybe sometimes exceptions are things that seldom get used but are needed , but even then at least have some form of access .
Makes for a way less stressful life but sometimes the only way to do this is to downsize because
you only have but so much space.
There is a ground point at the parking brake. Is that one under wood too? No way to pull a ground from the battery under the drivers seat?
What is the concern of mounting a negative bussbar to wood?
Discussion Starter #5
Yeah, the one at the e-brake is under the front edge of my floor.
Concern = wood is not metal.
I've tried to take multiple pathways to chassis ground. For example if you have an outlet with a ground wire, and your inverter is connected to the chassis (probably both the bare AC ground wire and the DC - connection), then maybe you can find a way to run a wire from one of your outlets to one of the many interior and exterior ground points (cargo hold-down bolts work great). Not every AC and DC circuit needs an independent connection to the chassis, but if you can run a few extra black wires and connect to the chassis in a couple spots, my thought is that it will help mitigate the risk in the future of one of the chassis points having the connection degrade and give me a confusing, intermittent electrical failure that might be hard for me to recognize, to find, and to diagnose. It also helps reduce the chance of ground loops. I actually connected a couple chassis ground points to each other with my own wires, besides grounding various parts of my system to different chassis points.
As far as mounting busbars--no problem mounting to something non-conductive. I try to mount + and negative busbars in a way that won't allow me to drop a tool or otherwise mistakenly bump into them in a way that will short + to -.
Take the plastic cover off the parking brake. You will find a bracket that bolts the parking brake to the driver's seat pedestal. That steel bracket has holes in it that can be used for a negative ground.
I went a step further. Did not ground the house system to the van steel. My house system is completely separate from the van electrical. That is possible because I do not directly charge the house battery through a relay to the vehicle battery. I can charge from the vehicle because I have a pure sine inverter powered by the vehicle 12 volt system. I take the 120 volt AC output from the vehicle powered inverter and power the shore power charger.
My walls are covered with cedar planking, I just went to the hardware store and bought a bolt that fits one of the D-ring bolt holes (7/16 Fine Thread) near the floor and used that to hook my Negative bus bar to with a single large cable.
Four years later and no problems.
Discussion Starter #9
I did find that. Could never get a solid 12v reading using that -- it bounced all over the place. Some combo of paint, or anodization/oxidation, etc... Even after some minor sanding to get at base metal it still had a lot of noise, so I rejected it.
Well the bussbar would need a negative to the chassis somewhere. My thoughts were you are concerned that the bussbar would be a mounting issue as far as heat etc. A ground path to battery is always your best bet. I that's not accessible you will have trouble in the future changing batteries.
Discussion Starter #13
If I could still get anywhere near my metal floor (it is buried beneath insulation, linoleum, plywood, and carpet) that would be a great, easy path.
I used the bracket for the ground for my vehicle powered inverter.
If I recall correctly there is a unused stud at the negative post on one or both of the dual battery installation on my 2015.
[QUOTE goingforspeed
Makes no difference that it's mounted to wood man.
[/QUOTE]
I always thought that it made no difference but then again I never actually bolted a metal ground directly to wood , reason being is that when you look at negative bussbar or negative posts why are they on plastic mounts if it doesn't make a difference ?
140391
I'd say cost but I'm an engineer. The last one I bought like that came with a positive boot cover too. I've seen airstream use a home bussbar bolted to the shell. That company does some weird stuff.
My negative busbar is mounted on wood. My positive busbar is also mounted on wood.
My system can see 200+ amps so I run the negative back to the vans dual batteries (2019). It also connects to house battery negative.
I'm still trying to figure out if the question was about mounting a conductive metal bar directly to wood, or an insulated bus bar assembly to wood.
At 12V the former shouldn't be a problem, but at very high humidity levels wood does conduct a small amount. This would only be an issue if something on the positive side of the circuit was also connected to the wood nearby. The importance of insulation/isolation increases with voltage.
But with all the insulated bus bars available for purchase, why wouldn't someone use one?
1 - 20 of 42 Posts
