Quick background: Had a 144" WB high roof Sprinter crew van for 4 years. Got it right before my son was born so I did the interior conversion in extreme haste. The wife tolerated it but was never very happy with it. Quite cramped for 3 and having all the aesthetics of my freshman year dorm room and a cargo van rolled into one. My windsurfing habit tends to soak everything in salt water and mud too. I talked to a boat builder about redoing it right and it was just going to suck trying to get everything to fit into a 144" with five seats so I got a extended length transit wagon.
Major accomplishments w/ the Sprinter:
1) Asphalt type sound deadening added to cover 70% of interior surface area, except firewall. Added insulation too. Way quieter, less file cabinet on wheels feel.
2) Recycled cabinets for storage
3) Storage for windsurf gear, MTB, and "office" space for work
4) DIY sound system came out pretty darn good
I'm heading out for a long road trip in a few days so I decided to get the new T350 to an acceptable state for habitation given I only have a couple evenings. I slept on the carpeted floor on the drive from Vegas to home and it sucked.
First off, the seats had to go. The rear row comes out easy with the easy pull latches, but the other seats need a screw driver or some sort of hook to pull on the metal latch underneath. Rock it forward and lift up. Where to put all the seats... will figure that out when I get back. My shop is now filled with seats.
Next, there has to be some way to carry wed and muddy stuff around without making the carpet disgusting. I decided to put down some sort of floor to create a barrier-- some underlayment with vinyl on top. I scored a bunch of free vinyl flooring when I tried to shoot a 3 pointer with a dirty diaper at an open dumpster and missed. Dumpster was filled with brand new vinyl flooring, more than I could possibly use. Stroke of luck! I went looking for luan at HD but found a paper/wood product with a water resistant barrier for $10 per 4x8 sheet. I decided not to secure this to the floor, it would just be floating. We'll see how that works. If it doesn't some stainless screws should attach fine to the floor...
I had my handyman assistant come by last night and we traced the wheel wells and other bits onto the sheets. The wagon interior is about 69" wide so we just overlapped two 4x8 sheets. We then cut out the wheel wells and other features. It fit. We left an inch of overlap with the plastic threshold near the rear doors.
The vinyl flooring comes in 4ft lengths. I bought the wrong glue. I got white liquid nails because it has worked well for me in the past. It takes too long to set and white glue comes up in the gaps between the vinyl "boards." A brown sharpie will fix that. We ran out halfway and used a general purpose bathroom adhesive I had lying around that worked great. Also in white. Shoulda bought clear.
First, a roll of vinyl would have been easier, but we had "boards". Don't put them down in a pattern. Do it randomly. Unless you like your floor to look like a checkerboard. Start from one end and go to the other, any excess you cut off and take back to the beginning to fill in the gaps. Easy.
The boards secured with liquid nails kept floating apart after a few minutes. I think in a normal room, the walls would provide some compression. We held them in place by lying a plywood sheet down and then laying a washing machine on top.
Took four hours.
For extra credit, I'll see if I can build a cabinet to go along one side. Looks like we'll be sleeping on mats on the floor for now, but at least we won't sleep diagonally (like in the shorter sprinter) or on top of D rings or seat rails.
For the record, the base wagon is pretty darn quiet already vs the Sprinter, so I'm debating whether a full deadening and insulation job is worth it. I can hear a bit of thudding when going over bumps, but I suspect that can be fixed with some spot fixes.
Took four hours.
