I made this door stop from 0.1" aluminum stock from HD. I used a 1" spindle sander to make 5 indentations space 6 inches apart on a 30" x 1/2" bar. I used 3M double sided tape to stick it down. It works well and took me about 20 minutes to make.
I saw another thread where someone made a single stop that was 3" x 1/4" x 0.1" with a similar indentation for the roller to rest in. The thread referenced a commercial version from Traipsing About (http://www.traipsingabout.com/2014/04/28/sprinter-door-stop-for-sliding-door/).
I made a similar version that was only 2 inches long, but it fell off after a week of use. I suspect I needed more surface area for the double sided tape. I also wanted more stop positions for the door. So I made a much longer version with multiple stops.
I attached two images. One shows the full length of the installed bar. The other is a close up of two indentations and the end bevel.
Cheers,
Jeff
Portland, OR
Cheers,
Jeff
Portland, OR
