1 - 3 of 3 Posts
got one of these monitors for camera system -
12 inch non glare screen - 1080p
build quality is good -
mounted up high with folding bracket -
can also mount on console
od is 11.5" X 7.5 "
this is a monitor does not have TV tuner inside
on amazon -->
Eyoyo 12 Inch 16:9 Mini TFT LCD HDMI HD Monitor Screen
1366x768 Resolution with HDMI VGA BNC AV Input for
PC Display CCTV Home Security (12 Inch)
[/IMG]
[/IMG]
How has this monitor lasted in your van? I am thinking of using one as a rear view camera monitor.
Many of these inexpensive monitor screens generate RF interference that will cause an error message for the Ford tire pressure monitoring system if the monitor screen is installed near the rear view mirror. The receiver for the tire pressure monitoring system is located in the headliner near the rear view mirror. I had to install a power switch for my postcard sized monitor screen to switch it off when the tire pressure monitoring system would show an error.
No errors with the nearby Garmin GPS or dash cam, only the cheap monitor screen causes the problem.
1 - 3 of 3 Posts
