Yes, I installed mine all the way in the back. I made a 14"x14" wood frame and glued it to the ceiling. Then I put my ceiling in. Later I cut out the plastic ceiling with a rotozip inside the 14"x14" wood frame. Then I drilled a hole on each corner, went on top and cut out the roof. I already had 12 volt power ran to it. Then when you screw the fan in place, the screws go into the wood for a really good deal. Then I put Dycor over the screws and lip. No leaks and works great!Hey all,
I'm wondering if anyone has successfully installed the Maxx Air Fan in the most rear position.
I want to place the fan directly above our bed. The spot of interest is the 14.25'' spot between two lateral structural supports. I will be able to cut a 14'' hole and just miss the structural support; however, the interior flange will need to be screwed through 1 additional sheet of sheet metal.
I placed the flange and it looks like it will fit. I may need to place 2 layers of butyl tape on the interior side of the sheet metal to better conform to the small weld ribs for appropriate plastic-to-sheet metal surface area.
Has anyone done this? do you have photos? run into any problems? words of advice?
Hein, your a popular dude.Been done 1000s of times using our external adapter and internal framing to specifically fit that bay. The framing is bonded to the roof and metal beams with 3M windoweld so no screws.
All the best,
Hein
DIYvan
