I think that's pretty much it. They say to go to the battery with the positive or to the access point under the hood. I went to the battery at the positive buss bar on the pre fuse box so I didn't have to run more wire. It's pretty much the same as if you ran it up front. I actually get all my positive connections there now. Much cleaner, but you must fuse them or use a breaker. Must is probably the wrong term, should is better.
Sent from my SM-N900V using Tapatalk
