Okay, so I have read through countless posts discussing different electrical set-ups and while I have learned a bunch, I still am not confident that what I am thinking about doing will work. Specifically in regards to compatibility and required components. I am considering three options and hoping to get some feedback. I realize that there is a lot of other components that I need, but I am just trying to compare the “big” picture items to be sure that I am starting on the right foot. Then I can get into the other details. I do want to thank everyone who contributes on this forum. I would be completely clueless (as opposed to just clueless) if it weren't for all the electrical diagrams and dialogue. And a huge thanks to FarOutRide for the detail you put into your site!! I have used it for guidance a ton! I am also hoping this thread will help out other rookies like myself.
Background: I would like to design a system that will work for a year long excursion around the US. I would guess that our longest stop (without driving will be 3 days). While I doubt that we will ever stay anywhere that has shore power, I would like to include it in the planning (just never know). Also, I have the single battery, 150 amp alternator. Here is the estimated daily usage: Fridge (32ah), LED lights (4ah), Maxxair fan (5ah), Water pump (1ah), charging phones/tablet (3ah). So that puts me around a total of 45 ah of daily consumption. Based on calculations, the total watt solar panel needs would be just under 200w, and battery amp hours needed around 120 ah. Let me know if any of these estimates seem wrong.
So I am considering these three options:
- First Option Similar to Anchorless
Charging from Solar:
2 -100w Renogy panels
CTEK D250S $214
CTEK Smartpass (necessary for my needs?) $224
Charging while driving:
Use CTEK $0
Shore Power:
Inverter - Magnum MMS1012 $815
*also used for AC circuit
*could I use cheaper alternative? Samlex PST 1000?
Battery System Monitor:
Victron BMV-712 Smart $206
Alternative: Magnum ME-RC 50 $155
Magnum BMK $165
Total Cost: $1,682
*IS VICTRON BMV COMPATIBLE?
PROS:
-Hassle free charging of house battery from both solar and van battery
CONS:
-CTEK limits panel size. Could do 2 – 180w Grape Solar for an additional $250 dollars.
-200 w is at limit of solar needs. Would likely need alternative charging (driving or shore power) or larger battery bank?
- Second Option similar to Far Out Ride
2 - 180w GS $470
Victron BlueSolar MPPT $197
Inverter - Samlex PST 1000 $418
Battery charger/converter - Samlex SEC-1230 $218
Samlex RC-15A inverter remote $29
*Will this inverter work with the 150amp alternator? Atoine states that the 230 amp alternator will
easily overcome the inverter draw to allow it to power battery charger/converter. I am not sure what this even means
Shore Power: $0
Uses same battery charger/converter
above to charge house battery
Victron BMV-712 smart $206
Alternative: Bogart Trimetric 2030 RV Solar $212 (Is this compatible with the controller?)
Total Cost: $1,538
PROS:
-larger panel(s). Would allow a some buffer and/or option to add to electrical demand (water heater? heater?)
-Use same battery/converter for shore power
CONS:
-Have to remember to turn on inverter when driving
-Not ideal if using inverter when parked
- Third Option
Charging from Solar;Single Larger Panel (32 volt):
280 watt panel $230
Victron BlueSolar MPPT (to reduce from 32v to 12v) $197
Charging from Van Battery:
Battery to battery charger - Sterling ST-BBW1260 (60amp) $391
Shore Power:
*also used for AC circuit (could i use Samlex PST 1000?) Samlex PST 1000
Magnum BMK $165
Total Cost: $1,839
PROS:
-I really like the idea of a single larger panel! Which I can get locally with no shipping cost. The only issue is it is an unknown manufacturer (Suniva or Jinko).
CONS:
-Eliminates the hassle free nature of CTEK from the equation.
-Most expensive (that is if components listed are compatible and complete; or related components)? May be cheapest if I can get away with cheaper inverter.
I will say that I am really leaning towards the CTEK as it seems like a nice no hassle way of doing things, especially for a beginner
. That and it seems like there are a lot of folks using CTEK with good results. The only thing I don't like is that 23 volt input limits the size of the panels that can be used.
CTEK D250S $214
Use CTEK $0
Shore Power:
Magnum BMK $165
Total Cost: $1,682
PROS:
CONS:
2 - 180w GS $470
Shore Power: $0
Total Cost: $1,538
PROS:
CONS:
- Third Option
280 watt panel $230
Shore Power:
Magnum BMK $165
Total Cost: $1,839
PROS:
CONS:
