1 - 20 of 30 Posts
You're likely on your own as those wanting more grip are lusting over 4wd conversions. I would love to know more about the locker, let me know how it works out!
No knowledge on arb locker and Transit's rear axle, but consider directing your questions to local 4x4 install shop or ARB on this question. I am also heavily considering the locker and intently following vancompass.com's effort to develop a 2+ inch suspension or body lift. With my camper build, I do not need/want 4wd, but extra traction and clearance are high on my list. Thanks for kicking off this thread, keep us comprised of your progress/install.
2015 350 Transit 3.5l EcoBoost
We bring our Transit camping a lot and I want to install an ARB locker in the rear. I can't afford a 4x4 conversion nor do I want the mpg hit that comes with it. I'm just wondering if its possible to install an ARB yourself.
Sure, plenty of videos on YouTube show how it's done. If you are a decent mechanic you should have no problem.
Sent from my SM-P900 using Tapatalk
Does the ARB locker for the 9.75" axle work on the full floating design we have? I believe it's unique to the Transit, and the carrier is going to be at least a little bit different as a result. We don't use C-clips to hold our axleshafts in, the 9.75" axle under everything else does.
Good questions Tom. I'm curious as I've been wanting to add an ARB locker at some point.
Any update on this? I spent the night on a fire road stuck last night and I'm not going camping again till I have all terrains and locker in. I have blown airlines on arb lockers in my jeeps in the past and have had 100% success with elockers. What companies make lockers for our axles?
When this thread started I emailed ARB right away to ask about it. The reply was prompt but they asked what type of axle I have. I replied I don't know. Still don't lol.
Has anyone here fitted a locker of any sort to their Transit?
I will spend the $ tomorrow if I can find one I know will work.
Well, ARB decided to be abnormally helpful with another response:) Technically it sounds like it will work.
"A c-clip diff will generally work in a full floating design, just not the other way around. Toyota 8.9" is a perfect example. There was a full float and C-clip version. There's a diff for both. You can use either carrier in the full floater, you just can’t use the full float carrier in the C-clip diff. It might work that way in your application, but we haven't tested fitment."
I went with a Eaton Detroit TrueTrac. This is a torsen style limited slip. I
http://www.eaton.com/Eaton/ProductsServices/Vehicle/Differentials/detroit-truetrac/index.htm
think most people who drive vehicles and are looking for traction on road and light off road would probably go for a limited slip as opposed to a locker type setup.
The locker would be better for rock crawling and extreme off road where a drive wheel would be physically in the air with zero traction.
The limited slip setup would be better for snow/ice traction on road.
What would be the primary reason someone would go with a locker on a transit? Just wondering.
Here is a good comparison article: http://www.fourwheeler.com/how-to/1101or-locker-vs-limited-slip-differential/
1 - 20 of 30 Posts
