I have a 2020 Transit 1500 with single battery and a single "always on" ccp post. I want to install a charger for my Yeti 1500x in the area behind the driver's seat. I have investigated converting the ccp power to "engine on" only but it seemed to involve accessing some small pins inside the battery compartment to operate a switch that would prevent draining the starter battery with the engine off. I could do that but it seems complicated and a bit of a hassle.
What I would like to do is locate auxiliary power point wiring. My manual says I have 3 12v 20a cigarette- lighter style power points. My dash has only 2 and the third is typically in the cargo area on the rear passenger post. I have a cut-out for the power point but when I looked in the access panel there was no connector there. I have seen a guy who was able to find and connect to a wire there. If I can find that wire I would have a 20 amp source of "engine on only" power that I could then run back to the area I want to locate my Yeti power box. I checked my fuse box and fuse 63 is plugged in and is supposed to control the 3rd auxiliary power point.
Is there any information from Ford that would show where the missing wiring might be? Or does anyone out there know how to find it?
