Hi,
Here is another test on cold weather charging protection for my poor abused Zooms battery...
This one looks at placing two 25 watt, 12 volt heater pads taped to the bottom of battery plastic case.
The two silicone pad 25 watt each heaters are siliconced to the grey alum sheet metal pieces which are then taped to the battery plastic case bottom. The bottom of case temperature sensor can be seen between the alum plates - its in direct contact with the plastic case and not in contact with the alum ( but close).
The top of battery temperature sensor is duct taped to the top middle of the plastic case.
The battery terminal temperature sensor is clamped under the positive terminal bolt - clamped pretty tight.
The pairs of red pairs of red wires coming up from the heaters are later attached to the battery terminals.
The thinking on the temp sensor on the battery terminal is that it might get a better thermal coupling the Li cells than the sensor mounted on top of the plastic battery case and still does not require opening the battery case to get to the actual cells.
The battery was encased by 1 inch polyiso.
A polyiso lid with a weight on it was added for the test.
There are a total of 6 temperature sensors:
- Taped to the top of the plastic battery case
- Taped to the bottom of the plastic battery case between the two pieces of alum
- Taped to the bottom of the actual cells
- Taped to the top of the actual cells
- Clamped into the Positive terminal of the battery
- An ambient air temp sensor in the air about a foot above the battery
This first plot is for the case with the two 25 watt heaters hooked up in parallel (50 watts).
The top red line is the sensor taped to bottom of case between the two heater pads (but not touching the heating pads)
The purple dash line sensor is taped to the bottom of one of the actual Li cells
The purple dash-dot line sensor is taped to the top of one of the actual Li cells
The solid aqua line sensor is clamped under the positive battery terminal (the wire from the positive terminal attaches to the Li cells directly, while the neg terminal wire goes through the BMS)
The plot may be hard to read - I copy to the Windows clipboard and then paste it into a picture edit program so I can blow it up.
Clearly looking at how fast the bottom of the case gets up to 240F, 50 watts coupled to the battery case in this way is too much. The bottom of case temp was actually hotter in that the sensor was not directly above the heater pad. The plastic where the heater pad was placed showed some distortion, but appeared to survive pretty well.
I had meant to watch the temps and cut off the heating if it got to warm, but got distracted and came back to a case that was very hot and smelling.
Maybe worth noting that the bottom of cells temperature went from about 55F up to 125F over the 40 minutes - probably not good for the cells. Meanwhile, the top of cells temperature sensor went up less than 10F. So, heat does not rapidly move into the cells and equalize across the cells.
This plot is for the case of the
two 25 watt heaters hooked in series. The amperage through the heaters was 1.1 amps, so total wattage for both heaters is about 14 watts (1.1 amps * 13 volts) - so, only
about 1/4 of the wattage for the other test.
This 14 watt setup might be fairly close to being OK.
It takes 2 hours (4pm to 6pm) to get the average cells temp up 16F.
There is still a fair bit of difference in temp between top and bottom of cells - at end of test top cells is 74F, bottom 103F, for a difference of 29F. Not sure how good this non-uniform temperature is for the cells?
It does not take very long after the heater is turned off for all the temps to come together - so, maybe a half hour waiting period after the heater is turned off would be good before charging?
It would be a pain to damage the battery with uneven heating while trying to protect it from damage due to charging below freezing
One of the new LFP batteries with a heater built in wraps the heater around the sides of the battery - this might be a way to get more uniform heating. The new SOK heated battery puts the heaters between the cells, which seems like a good plan to me.
It appears that any way you slice it, warming up cold batteries before charging is not going to be a 10 minute thing.
The sensor clamped in the + battery terminal follows the top of cells temperature pretty well - so, this is good. With the heater on the bottom as for this test, it will underestimate the average temperature of the cells in that the top of the cells is their coolest part.
I think some kind of a temperature controller that would cycle the heater to prevent overheating the cells locally and could also be used to turn the heater off altogether when the cells get up to temp would be a very good thing?
Its clear that there is a lot of potential for damaging the battery if a lot of care is not taken in the design of the system.
On observation is that if the battery is in an insulated container, it would not take a lot of juice to just keep the batteries warm as the outside temperature goes down below freezing. The 2nd test used just over 1 amp-hr per hour and it heated the batteries up at about 8F per hour - so, (maybe) less than half and amp-hr per hour would keep the batteries from getting cold?
Just to follow up on the keep the battery warm rather than heat up a cold battery idea...
A 1 inch thick polyiso enclosure for 2 SOK size LFP batteries is about 7 sqft and would have an R value of about 6.
So, the heat loss per degree F of temp difference between inside and outside the battery compartment is (7 sqft)(1F)/(R6) = 1.2 BTU/hr-F or 0.35 watt-hr per hour, which is 0.03 amp-hrs per hour per degree F.
So, to (say) keep your battery at 35F when the temp around it is 0F would take (0.03amp-hr/hour-F) * (35F - 0F) = 1.1 amp-hrs per hour.
So, you could let the van go cold in 0F weather, and the battery could keep itself warm for 26 amp-hrs over a full 24 hour day.
Or, half that if the outside temp was 20F.
Not so bad?
The caution would be that you would have to be careful that the battery did not overheat in its insulated container. But, the LFP batteries have such low internal resistance to generate heat that it might not be a problem?
Any thoughts on this? Better ways to do it?
I have two of the SOK 100 amp-hr batteries in my van and so far have not taken any steps to provide a heater. But, we do enough cold weather camping that we will have to do something eventually. SOK has since come out with a heated version of my battery that also has a Bluetooth BMS for $590 (only $20 more than I paid for the unheated one). I would definitely have gone that way if they had been available.
If you like camper van tests, there are a
few more on my site you might like... These are on various topics.
Feedback is very welcome!
Gary
