1 - 9 of 9 Posts
Somewhere in the past I've seen a more up-to-date Ordering Guide, that lists all the option codes. I have one dated 1/15/14, but know there's something more recent.
Anybody have a link to the latest, hopefully in .pdf form?
Thanks...
Your dealer can and should print one out for you. Both dealers I have talked to offered it without me asking (after my option questions became more detailed than they could answer). My latest (acquired end of August) was updated to 1 Aug. Unfortunately, my copy is only a printout or else I would share. Getting the invoice/msrp option price list out of them was harder, but it helped I was X-plan which is invoice based.
I have seen the 8/1/14 guide also, but cannot find it online. This newer version may be behind a firewall IMO.
I did find this Hot off the Press page:
https://www.fleet.ford.com/truckbbas/topics/hotinfo.html
which has the following as of this month:
https://www.fleet.ford.com/truckbbas/non-html/Q-225.pdf
The PDF link under "Description" does not open up, but here it is via copy and paste of the pdf link:
https://www.fleet.ford.com/truckbbas/topics/2015/20
No Drill Zones are clear on p. 55.
https://www.fleet.ford.com/truckbbas/topics/2015/2015_Transit_BEMM_v1-0.pdf
I have not compared this to the manuals linked elsewhere by JP4.
FWIW!
[Edit -- running out of time to clean up the links above -- some work -- some do not!]
Thanks Peter, but I am looking for a recent guide that lists all of the option codes for specifying a Transit for purchase.
Yes, as I said above, I have a hard copy of the 8/1/14 updated guide, but cannot find the online version of it. If there is a particular option you need the code for, I can check for you. As jethaden said, your local dealer should be able to give you a copy.
The other links were FWIW "finds" in case they are handy for someone.
I have looked high and low for an online version of the 8/1/14 order guide. Even the older January one is available only as an attachment on other Transit forums. Both versions are probably behind the Ford firewall which requires a user ID and PW.
Good luck Brad.
[ford transit forum dot com]
1 - 9 of 9 Posts
