that’s a good point, I’ll look at that tomorrow. Maybe I’ll add an offset to the bracket.The one i bought (off someone on etsy) the issue is you can’t move the seat all the way back
Not sure the measurements on your design. Finally measured ours. 5-1/2" wide, about 20" high. Just enough to hit the upper bolt hole. Doesn't look like the lower little angle piece we added helps any. I would not expect this design to be similar to a 2-bolt that doesn't use the lower big bolt; I'd expect this to far more solid. I don't have a comparison, of course, but this setup in 1/4" aluminum is really, really solid. I can't think of any reason to use 3/16" versus 1/4".I am about to order the below. Any last thoughts on what you wish was different for your bracket that you may have used?
I am thinking 3/16" should be plenty, no? or 1/4" better.
I know @gregoryx yours is 1/4", no?
Any other recommendations or features you wish you had?
I haven’t tried it yet but can’t you separate the arm from the table?Not to hijack the thread, but also curious where you folks store your table top when not in use. I'm scratching my head right now trying to figure out where in my build to store the **** top as it has a giant protrusion due to the Lagun mount.
Sure, you can separate it but you're still left with the giant mounting plate.I haven’t tried it yet but can’t you separate the arm from the table?
i was planning to store it behind third row, since the seats recline there is a gap to cabinets where we store a bunch of flat stuff.
what’s worse is the zero breeze I just got, that thing is bulkier then I thought, ha
Two locations for us: one sits in a space near the rear windows with the table leaning against the metal divider; the other is just behind the driver's seat. Both work fine.Not to hijack the thread, but also curious where you folks store your table top when not in use. I'm scratching my head right now trying to figure out where in my build to store the **** top as it has a giant protrusion due to the Lagun mount.
Got any pics of it behind the seat? I'm contemplating just having it always mounted and just pushing it out of the way but would definitely prefer if I could hide it away somehow.Two locations for us: one sits in a space near the rear windows with the table leaning against the metal divider; the other is just behind the driver's seat. Both work fine.
Do you feel comfortable with the 2x bolts at the Pillar? I was concerned about it possibly flopping around a bit and that 3rd bolt on the bottom would give me more structure but then I have no idea If that’s needed or notI designed one too, but didn't want to try to use the floor hole location - as this will be covered up by our AVCrig floor.
.187" thickness felt a bit too thin, I ended up with .250" which is quite sturdy. I also had the holes tapped, to try to avoid nuts sticking out in the rear of the Lagun mount.]
After 16.375Nm tightening torque it felt flush-ish enough. HahaThe challenge with the floor 3rd bolt position is it's not flush (at least in my van) with the other holes, thus I'd need some spacers and/or bend the plate.
