101 - 120 of 128 Posts
2019 MR non-ext
For those having trouble getting the newer KB3Z-14A626-A keypad to work with your pre-2020 Transit, you may have to first configure the keypad to COMMUNICATION TYPE 1, as outlined in the PDF that is attached to post #58.
In the PDF follow the instructions under "Configure Device" to change your keypad to "communication type 1". (Note that after you press the "1/2" to change the communication type, you must press the "5/6" key to confirm the entry. I missed that at first because it's on the next page.)
After you've configured the device, then follow the instructions under "Type A - Programming and Installation" to program it to your Transit.
I was having the same trouble that many others were having with the new style keypad not wanting to sync up with my 2019. After I found and followed the instructions from the PDF, it all worked!
Hope this helps someone.
This worked for me once I searched for it, thanks a lot
Here are the instructions to check/set the two different modes on the keypad. The default mode "communication type 1" is the correct one for the Transit. Probably not your issue but worth checking.
5. Upon pressing the 1/2, 3/4, and 9/0 buttons simultaneously for at least one second, all five buttons
will flash at a two flashes per second rate. This indicates the keypad is waiting for master code
entry. The master code is entered as in a normal keypad unlock, each button press will give another
five second window for the next button press. If no button is pressed within five seconds the
configure mode will exit.
6. When the proper master code is entered the 9/0 button will flash a pattern that corresponds to the
current protocol set:
• One flash per second for "Communication Type 2".
• Three flashes per second for "Communication Type 1" (Default).
7. You will have 10 seconds to:
• Press the 9/0 button to change the protocol to "Communication Type 2".
• Press the 1/2 button to change the protocol to "Communication Type 1" (Default).
Thank you for posting this procedure it worked for me! I tried two new remote keypads from 2 different Ford dealers they did not work. The older part number is ES7Z-14A626-A. The newer part number is KB3Z-14A626-A. I was able to get the KB3Z-14A626-A to work after following this procedure. Thanks Rick 2018 T350 15 Passenger DRW
Here is the factory instructions for installing and programming the rf keypad
Direct link to spotco2's post #58, which has the PDF link: Keyless Entry Installation 2018
spotco2, JRG, and anyone else, thanks so much! I just got the new style keypad, to use on my 2013 Transit Connect. I note that the PDF file is from 2015 (by the title), when Communication Type 1 was the "default", per the text. Obviously, now, that's not the case. Switching to type 1 fixed me right up.
Here's a photo of the slightly larger, new keypad, compared to the older style that is on my 2015 Transit 250.
151191
Also, a look at the back side makes me think this new model may open up non-destructively, for battery change, due to having tab locks all the way around. I seem to recall that the old one required minor cutting and re-gluing.
151192
Following up, here, for the 2018 keypad question, and on another thread for the 2020 keypad question...
I noted in that PDF file, that there's a chart indicating that later Ford vehicles must be set up with the dealer's IDS software.
Now, a quick glance at the chart on page 2 of the PDF would have you believe that all Transits from 2014 onward, used the same, user programmable "4 turns of the ignition" (Installation Method A) type thing. BUT, this document is from 2015 (see the filename). The writer was just projecting the future. Since the newer models in the chart all went to Installation Method C / IDS, we may expect that to be true of Transits, at some point... possibly 2018 or 2020... not sure.
I programmed the keypad myself (2018), and it was either 4 or 8 key cycles to activate the procedure, same as keyfob remote programming.
Reactions: asdrew and EddieZ
Would you mind posting the link for the other 2020 thread you mentioned? Thanks!
Another installation story: 2018 Transit 250 - I ordered 3 keypads part number KB3Z-14A625-A 1X. On the keycode-card for two of the keypads, there was a label "314.95 MhZ". The other keycode said "902.75 MhZ". The 314Mhz pads had a manufacture date of Jan 2021. The 902Mhz had a manufacture date of Feb 2020. I had to reset the 314Mhz keypads to use "communication type 1". Then they worked using instructions posted earlier on. The 902Mhz never worked.
Holy smokes this is complicated. Sympathy to any poor soul who is still reading this thread.
You lucked out, by getting instructions for the mode change.
So true. Without this forum, forget about it.
The funny thing is: if you boil down the 117 posts, all the trial-and-error and discussion across variety of different part number and van models, the actual programming checklist is quite short. Half page of text, maybe a page.
Someone ought to create an automated checklist generator. Any good programmers here?
2018 T-250 Medium Roof
What about relying on the average Ford dealer to help provide real answers and help? :oops:
The Ford dealer I had gone to to install two more on my van, when I first got it, told me to go to a sound system and alarm store. They didn’t even know they could sell me more.
The dealer I bought the van from, could not figure out how to program it. Took them as hour to learn how.
