1 - 10 of 10 Posts
2020 T350 EB SRW AWD HR EL
32 TPI or 21 TPI for cutting holes?
I thought a finer-tooth blade would be better, but 32 TPI may move too slowly and creating more heat. Jigsaw is my least favorite when comes to tools, but can't delay any longer.
I saw a carbide tooth blade the other day, not sure of the TPI. I swear by the expensive carbide sawzall blades now.
I'd go with the 21 myself.
2016, MR, 130"
I'd go with 32 TPI but the 21 would do. Just move slowly. As noted above with the thin sheet metal of a Transit the 32 would be what is recommended.
If you need an excuse fro an extra tool, this wins, or ones like it, i cut from underneath, 5 minute job max, including drilling holes for corners!
whoa, that's only about twice the price of a carbide jigsaw blade! For a whole tool! The design of it would definitely be easier to use than a jigsaw.
To build on @AlexG 's answer, the recommended coarsest TPI you should use with while sawing metal is one that ensures there are at least two teeth in contact with the cut. Any coarser (smaller TPI #) and a saw tooth will be prone to bind, distort the workpiece, or be damaged.
At 32 TPI, you get 0.032" between teeth. If the metal is 1mm (0.039”) thick, you are already technically using a blade that barely meets the optimal criteria.
Will it work? Sure it will. Best results will be achieved using constant light forward pressure and angling the cut to increase the blade contact length. Don't just keep pushing if the cutting progress slows. Change the blade.
1 - 10 of 10 Posts
