what is the best and safe auto jack stand to use in ford transit?
How are you going to do that? There's only one lifting point per corner, that you would need for either the Jack or the stand. It's not like with a frame where you can lift a few inches to one side in order to place the stand. This has frustrated me already.I plan on using my cheap 3 ton Torin Blackjack jack stands + powerbuilt all-in-one.
My other unibody vehicle I can lift one side of the SUV at a time. With the Transit I'll have to do one corner with the jack, throw in a stand and repeat. With the 130" wheelbase a side at a time may be attainable.
Haven't jacked mine up, yet, but I'd probably put the jack under the axle and then put the stand under the lifting point.How are you going to do that? There's only one lifting point per corner, that you would need for either the Jack or the stand. It's not like with a frame where you can lift a few inches to one side in order to place the stand. This has frustrated me already.
Well, the rear axle is the lifting point, but, yeah, it's more doable at the rear, though I don't think you're really supposed to lift further inboard than the prescribed point. The front, though -- I don't see how a stand can be placed... 'cause you'd already be jacking the only available support point.Haven't jacked mine up, yet, but I'd probably put the jack under the axle and then put the stand under the lifting point.
I bought a pair of 4000# ramps the other day.
Completed my first rotation today, and checked the brake pads, etc. I was able to squeeze the jackstand and jack right next to each other just barely on the front side. I didn't have much luck getting the jackstand on the back unfortunately. In the end I had no real choice but to use the Ford supplied jack and the power built on opposite corners of the vehicle. Made for a super tedious rotation in the pattern prescribed in the owner's manual.How are you going to do that? There's only one lifting point per corner, that you would need for either the Jack or the stand. It's not like with a frame where you can lift a few inches to one side in order to place the stand. This has frustrated me already.
Those might be points to lift with an overhead post lift. Even without illustrating the transmission crossmember.I just can't understand how there are only 4 prescribed jack points on something so big. I guess what easier way to force dealer servicing...I don't expect to raise one side from the middle, but there must be a spot for the whole front end for example.![]()
Yeah, you would not want to put a bottle jack under the pad-points in that diagram. The point load would be likely to cause deformation.Those might be points to lift with an overhead post lift. Even without illustrating the transmission crossmember.
Owner's manual shows jack points at rear axle, simple enough.
The front jacking points gets a little bit confusing. Their explanation makes me think it's a circular pad with a hole in the center at the rear of the front subframe. This flat area has a decreasing wall or up right around about half of it.
So I check with 3 dealerships and get three different answers.
Mechanic number one-- further forward on the front subframe.
Mechanic 2--at the three or four inch cylinder bar at the outer edge of transmission crossmember.
#3-- just in Board of that cylinder shaped bar on transmission crossmember.
Any ideas?
Suitcase
Yeah, you would not want to put a bottle jack under the pad-points in that diagram. The point load would be likely to cause deformation. I'm with Mechanic 2.
I have the same one, but mine had a tendency for the piston to stick in place (which then means using another jack to relieve pressure and then force the piston down). After a few uses that issue seems to have gone away, but I still have to use another jack on my other vehicle to clear the Powerbuilt. Someone's suggestion of a 4x4 helped me use my 3.5ton jack pointed towards the rear of the vehicle and slip the stand in from the front, but it's way more difficult than it should be.This is so F-ing retarded. Of course someone's gonna need to jack and then stand their van. How did they think folks were supposed to do this? As others have said, the back is easy, the front is impossible from what I can see.
So, I broke down and bought the Powerbuilt all-in-one. $39 through Amazon. I may replace the stock jack with this one since I don't want the van falling on me when I'm changing a tire. FYI, it doesn't have much extension, you might need to shim it with a block of wood, especially if you have oversized tires. It was at maximum extension with the stock tires and I couldn't lock it. Needed the shim to lock it with the stock tires.
I sure hope I don't have to use another jack to lower this one. Carrying one jack is enough!I have the same one, but mine had a tendency for the piston to stick in place (which then means using another jack to relieve pressure and then force the piston down). After a few uses that issue seems to have gone away, but I still have to use another jack on my other vehicle to clear the Powerbuilt. Someone's suggestion of a 4x4 helped me use my 3.5ton jack pointed towards the rear of the vehicle and slip the stand in from the front, but it's way more difficult than it should be.
