21 - 35 of 35 Posts
Discussion Starter · #21 ·
Just started my C&C install. Mounted the condenser where the spare tire was. (Spare is now mounted on a rear door tire rack and ladder combo for aluminess). I set the condenser at 20Deg angle, the minimum is 15 deg. Used 3/16" aluminum stock and bent it to the correct angle. Attached to van with 5/16" bolts and Rivnuts. Took a little while to make sure I could route the refrigerant lines up to the evaporator, but will work. Overall took me two half days to complete the install. I will put some metal screen in front of the condenser to stop any road debris from damaging the heat exchanger fins.
View attachment 151476 View attachment 151477 View attachment 151478 View attachment 151479 View attachment 151480
Nice! Thanks for the info. Will be interesting to see how it works out for you. Keep us posted.
Discussion Starter · #22 ·
Hi, any thoughts on how this is working out in terms of cooling capacity and power consumption. Does it seem that it was sized right in terms of cooling capacity and efficiency. The reason I'm asking is that I was planning a similar capacity system, but had an up-fitter tell me that I need a 3 ton unit for the van. That's the size of the one in my house! Seems like overkill and I think would cycle on and off too much, not to mention the power consumption and weight.
· Premium Member
3T is 36,000 BTU. That would be a freezer in an insulated van. The carrier Reefers uses for refrigeration put out less BTU's than that. I can't imagine this outfitter is well versed with A/C systems.
Discussion Starter · #24 ·
I'm not familiar with the carrier Reefers, but another benchmark is that typical sedan AC systems are about 3T capacity according to here's a paper I'm going to read to try and get some insight. It's not directly answering my question but it gives general ideas of automotive AC power consumption scenarios: https://www.sae.org/standardsdev/tsb/cooperative/mobile_ac.pdf. So bottom line is that I was skeptical when told I needed 3T but am looking for some "science" in the thought process. Benchmarks are a big help and actual results in real world systems are very useful.
Discussion Starter · #25 ·
By the way thanks for the link, looks like useful stuff. I have not had much luck in getting quotes for parts I need.
· Premium Member
Automotive A/C engine drive AC systems are designed to cool your vehicle very quickly after it has reached some really high internal temperatures, as a result once temp is achieved the compressors cycle heavily.
Standard 110V rooftop A/C are around the 15,000BTU/hr range and do not cycle very much on a hot day, they just run full blast.
It completely depends on what you are trying to achieve.
Discussion Starter · #27 ·
Thanks, this makes sense. I don't plan to cool the RV quickly as when you get into a hot car. The use case for us is that we plan on being outside usually during the day and using the vent fans to keep it at ambient or slightly above. The need for the AC will be mostly at night to have a reasonable sleeping temp in hot/humid climates. We also hope to use the AC to get the humidity out in cooler . rainy weather just as a car AC helps defog the windshield. The van is the silver ingot color so not as cool as white, but hopefully not too bad.
Finished my install of Cruise&Comfort 8kBTU HD-12L, 12 Volt DC Air Conditioner split system and wanted to share some pictures and performance data.
The Condenser is where the spare tire was and the evaporator/compressor is on the rear passenger side over a 22 gallon water tank. The refrigerant lines run thru the passenger side walls down to the channel/cavity behind the bumper and I cut a 2" hole behind the condenser to route the connections. Added R134a refrigerant, needed to buy a set of manifold gauges, fairly straightforward with instructions from C&C and a YouTube video from Login • Instagram.
The dual fan C&C condenser can be wired in parallel or in series with parallel being high power, louder and series being lower power and quieter. I was trying to see if I could use a relay to switch between parallel and series; luckily a huge thank you to going_boundless for letting me know I could use a DPDT switch to accomplish the same.
This weekend we took the van out to northern CA and ran into some high temps (+95) during the day. The unit does a great job of cooling the back of the van and we had it on during lunch and it was very comfortable.
As far a current draw and noise, I did a test today comparing parallel and series. The dB readings are with the rear doors close; the sound meter is about 4 feet back from the van and waist high.
Parallel: Current draw ~50 Amps, noise level 70 dB
Series: Current draw ~ 40 Amps, noise level 55 dB
It is much quieter in series >10 times quieter vs parallel, a good option if you are in an urban area or have close neighbors.
Condenser in spare tire location
Automotive lighting Automotive tire Motorcycle Wheel Bicycle tire
Final install - testing parallel and series options
Floor Flooring Gas Machine Wood
2021 AWD Transit 350 148" Long HR
Do you think the condensor could fit in other locations underneath the van without decreasing ground clearance?
I was hoping to keep spare tire underneath while putting a gray water tank under the driver's side and condensor under the passenger side.
I think it will fit on the passenger side, the angle might need to be increased. Also the exhaust is on the passenger side so be careful not to get too close. When you place the compressor/evaporator in your design check how long the refrigerant lines need to be. I was able to use the standard size (I think it is 7 feet). If you need a different size I believe C&C will make custom length. Best is just send them your design and prosed line routing to ensure you get the correct length.
Thank you for documenting your install!
Can you please share details on how you routed the lines into the van? What hole diameter did you drill, how tall is your floor stack, how are you protecting the lines?
Hi @eranrund, here are some details on running the refrigerant lines from the condenser fan up to the main C&C unit in the van using the default 7 foot long refrigerant lines. No holes were drilled in the floor, we have a LWB van and the condenser is as far back under the van where spare tire was. I accessed the "channel" behind the rear bumper and run the coolant lines internally through the back of the van up through the wall cavity into the van; no floor penetration necessary. Unfortunately I did not take pictures of the internal run, but the 7 feet did work with not much to spare.
  1. Condenser install, with protective screen (1/4" stainless steel mesh folded over once). The refrigerant lines are on the left protected with pipe insulation covered with aluminum foil tape.
    1. Automotive tire Vehicle Bumper Automotive exterior Composite material
  2. Penetration for refrigerant line. Used a hole saw and widen with jigsaw, then protected edge with the same material used for windows. To seal the hole cut a "cover" of expanded PVC and sealed with silicone RTV ( had a tube of the red color). It is tough to keep the RTV application neat; but has held up through the past winter
    1. Automotive tire Hood Motor vehicle Tire Automotive design
      Hood Automotive tire Automotive lighting Motor vehicle Bumper
  3. Refrigerant lines over water tank. (BTW: Pos and Neg wires are 2AWG - ran from 70amp breaker)
    1. Motor vehicle Hood Automotive tire Gas Electrical wiring
      Hood Automotive lighting Automotive tire Motor vehicle Bumper
  4. Overall install - from last summer:
    1. Vehicle Motor vehicle Gas Engineering Machine
I’m new to the forum and plan to order a Transit Cargo van, 144” wheel base, dual rear wheels, high roof, extended/long body, AWD and convert it to a class B RV. I've spent the last 2 months on this to develop requirements and come up with a conceptual design of the system. For the HVAC system, I plan to run a hydronic heater and an under van mounted 12V compressor & condenser for HVAC use with a rear heater/A-C unit (not coupled with the vehicle) when not driving. The heater would also provide hot water through a heat exchanger. The compressor would be powered by a 600 AH 12 volt lithium battery bank and about 800W of solar on the roof. Don't really want to put AC on the roof. Has anyone on this forum already done this on a Transit? Any suggestions or advice? I am really lacking geometric information of the underside of the van to place the A/C components - and tanks for that matter. There is a separate topic for tank placement that I have started to sort through.
Hi! I'm new to this forum as well and am contemplating my first van build. Have you seen this YT? The way he put it together is pretty slick.
    1. View attachment 168952
    1. View attachment 168953 View attachment 168954
    1. View attachment 168963 View attachment 168956
    1. View attachment 168957
Awesome, thank you so much!
21 - 35 of 35 Posts
