1 - 20 of 35 Posts
I’m new to the forum and plan to order a Transit Cargo van, 144” wheel base, dual rear wheels, high roof, extended/long body, AWD and convert it to a class B RV. I've spent the last 2 months on this to develop requirements and come up with a conceptual design of the system. For the HVAC system, I plan to run a hydronic heater and an under van mounted 12V compressor & condenser for HVAC use with a rear heater/A-C unit (not coupled with the vehicle) when not driving. The heater would also provide hot water through a heat exchanger. The compressor would be powered by a 600 AH 12 volt lithium battery bank and about 800W of solar on the roof. Don't really want to put AC on the roof. Has anyone on this forum already done this on a Transit? Any suggestions or advice? I am really lacking geometric information of the underside of the van to place the A/C components - and tanks for that matter. There is a separate topic for tank placement that I have started to sort through.
You could mount the compressor unit in front of the spare. Lots of room, deep cavity. There are also big cavities next to the fuel tank and muffler on the sides.
I'd recommend going to a ford dealership with a cardboard sheet so you can crawl under and get the measurements you need.
If you can find a Hr Extended in stock anywhere.
Any info on the "12V compressor & condenser" you are looking at using?
Also, what advantages do you see in hydronic heating over diesel air heater and electric water heater? I have been leaning toward the latter for simplicity and longevity. The diesel heaters seem to have a limited lifetime but are cheap to replace.
Have you considered the resale value of the van if you go with a custom "non serviceable" HVAC solution?
E450 Wagon
I don’t think the OPs system needs to be considered “non-serviceable”.
Webasto make complete systems for the Transit including underbody condenser. The only thing their package lacks is the 12-volt compressor, but they sell those as well, so I suspect it would be easy to get them to modify the standard package to include that compressor.
Ford Transit Vans
Webasto Brochure
How are those Webasto systems offering 32K-42k btu of cooling and heating with such low amp draw?
Considering other AC’s I see with 13,000 btu are 5-6x the amperage ?
In our van we have a Rixen hydronic heat system for hot water and air. For AC we use Cruise-&-Comfort 12v system. The Rixen system works very well at high altitude and sea level. We will be testing the AC system this summer. I calculated if you run the AC system for 3 hours at 40 amps draw will drain 120Ah. Important to size your system for the typical needs. Our insulation is, thinsulate with EZ cool air gap on ceiling, and ceramic coating on all windows.
Discussion Starter · #10 ·
Thanks, I plan on doing this.
Discussion Starter · #11 ·
Thanks, I am looking a the Rixen system also. Are you using the the VES-12s or VES-12L Classic? Does the blower assy come with or can you add a heater core to it? Or is the heater core integrated with the Rixen system? I'm trying to avoid 2 blower fans.
Discussion Starter · #13 ·
Thanks. A few more questions:
1)what is your fan set up?
2) do your windows open for ventilation?
3) Do you have solar on the roof?
4) What color is the van, I think this matters for the thermal model. White vs. color vs. black. Not sure how to evaluate, but a test would be worth a lot.
Discussion Starter · #14 ·
Ford Transit Vans
Webasto Brochure
Just talked to a Webasto rep and they only offer engine driven compressors, which does not meet requirements for this application.
Discussion Starter · #16 ·
The main reason for not relying on electric for hot water is the power draw when off grid. With hydronic heating, most of the energy comes from the gasoline which is already on-board and more cost effective than battery storage as a source. With electric heating, raising 7 gallons of water from 70 to 120 F would pretty much draw down a 12V 100 AH Lithium battery to 28% and it would take 36 minutes with (my 1440 watt) electric heater to heat it . This all assumes perfect efficiencies which there never are. I do plan using an electric heating element if we are connected to shore power.
The second reason is that I can use the AC blower and ducting to more evenly distribute the HVAC airflow. I think it's going to be quieter, but I'm not sure. I'm looking for some noise info, but haven't tallied it yet.
The third is to consider using the heater to freeze-proof the fresh water tank via a little recirculation, not something I would want to do with batteries. In cold climates this could seriously impinge on remaining battery capacity.
I don't consider the A/C system non-serviceable because there are nationwide service centers for it. The heating system's core is from Eberspacher, which I don't consider non-serviceable. The jury is out on the surrounding other heating components, potentially from Rixen's. It looks like they make quality stuff though, just not sure about servicing yet. I haven't talked to them.
Nevertheless, I don't put resale value high on my priority list. I've been camping all my life in multiple setups and plan on keeping this conversion until it is almost fully depreciated / worn out. I do agree though, that this should be considered in case something unexpected happens, just not giving a lot of weight right now. I would rather get what I want to use than sacrifice for what might happen in the future.
  • the C&C system we have is : HD-12L Mobile 12 Volt DC Air Conditioner split system. 8k
  • Fan system - maxxair as far forward as possible
  • Tern Overland roof hatch
  • Windows - AMA half sliders on driver and passenger
  • 200 watts of solar. 2 - 100W renogy panels.
Automotive parking light Automotive tail & brake light Vehicle Window Car
How do you like the CNC AC?
Just started my C&C install. Mounted the condenser where the spare tire was. (Spare is now mounted on a rear door tire rack and ladder combo for aluminess). I set the condenser at 20Deg angle, the minimum is 15 deg. Used 3/16" aluminum stock and bent it to the correct angle. Attached to van with 5/16" bolts and Rivnuts. Took a little while to make sure I could route the refrigerant lines up to the evaporator, but will work. Overall took me two half days to complete the install. I will put some metal screen in front of the condenser to stop any road debris from damaging the heat exchanger fins.
Tire Wheel Car Vehicle Table
Tire Wheel Vehicle Car Hood
Tire Automotive tire Tread Wheel Automotive lighting
Automotive tire Plant Asphalt Car Vehicle
Wheel Tire Automotive tire Automotive lighting Tread
1 - 20 of 35 Posts
