1 - 7 of 7 Posts
With Ford making changes to the 2020 Ford Transit orders, be sure you are in contact with your dealer if your order has the Front Fog Lamps or the Push Down Manual Parking Brake on your order. These 2 options may have put your order in a 'Unscheduled - Compatibility' status and will keep your order from being pulled for scheduling. Some dealers may not recognize this will hold up the order so just making you aware of this in case your order has not been scheduled.
I have contacted all of the Matt Ford customers so they can make the decision on the Front Fog Lamps and the deletion of the Push Down Manual Parking Brake from the CrewVan and Passenger van orders. Ford has made updates based on a NEW 11/11/2019 Ford Transit Order Guide but it has not been published on the Ford Order system yet but we know at least 2 changes were made with the Front Fog Lamps/Exterior Upgrade package and the deletion of the Push Down Manual Parking Brake for the CrewVan and Passenger vans.
Aren't fog lamps part of the xlt passenger build and/or HID lights? Or is this delay just if fog lamps are a separate line item add?
Thanks for the heads up, I think it's been mentioned if your order has already received a VIN & build date it should not effect the order status is that right?
Discussion Starter #7
Most of the changes in the latest 11/11/2019 are for the CrewVan and Passenger vans and nothing on the Cargo van.
NO NEW printed version on the 11/11/2019 Transit Order Guide is available yet.
1 - 7 of 7 Posts
