Hey everyone. I have an idea for flushing the heat in summer and possibly capturing a bit in the couple cold mos here (Jan&Feb). Will you critique it? If I do it I'll be sure to provide feedback.
I understand heat will accrue regardless but having slept in 95° for several nights one summer without ac I'd like to funnel some up and out between the skin and wall instead of insulation absorbing then releasing through the night.
If I attach radiant barrier to both the skin and the inner wall there will be an airgap Between them. The hot air inside could rise through the ribs into the ceiling gap and through side vent holes in the underside fan frame. Heat heads out with fan assist And floor vents providing circulation.
In the winter I could close the side fan vents and direct heat insidelby opening lower down vents (slightly higher and away from fresh air lower vents). Closing all vents at night would slow inside air from exchange with colder outside air.
Any thoughts? The journey of the build is as important as the roadtrips. So,, I'll take it in stride if I come out the wiser and make improvements along the way.
Floor is lightly insulated with insulating roof paint. I'll be adding ceramic beads with inert gas into the insulating paint for final coats on top of van roof. Front window facing as needed from the sun. Shade, breeze, ventilation all to be used.
Thanks ahead for consultation and/or brainstorming and support.
