English is a strange language ... contranymi reused the trim. I just "trimmed" it.
trim - to embellish
trim - to free of excess or extraneous
Just make cure you don't clip the clip when you are trimming the trim.
Nope. I don't do phones. I just cut about an inch and a half off the bottom following the factory shape. Took 5 minutes. It's not mounted to the floor anymore but it sits there fine.Nice! Happen to have pics of the process?
How about cameras? Do you still have one of those? I use mine more often than the stupid phone, because I'm a luddite and just keep my phone in the van for when I might need it.Nope. I don't do phones. I just cut about an inch and a half off the bottom following the factory shape. Took 5 minutes. It's not mounted to the floor anymore but it sits there fine.
The problem I had with it is it made me really bend the cable towards the rear of the van. I didn't want to force my cable back that far so I just lowered it.To further on this post I've installed the Amazing Auto swivels on a 2019 Transit with the 10 way power/heated seats.
tngw1500se mentioned in the first post there was an issue with the bracket they provided to lower the parking brake. This may be the case for a 2020 but I can confirm it not a problem on a 2019. I had no issues with the bracket they provided to lower the parking brake. They have an instructional video on their website that is easy to follow.
I don't see how. Pop the upper cover off the brake and then remove the lower. They both pull up to remove. There's just no room.I also have 2020 awd with a power outlet. was wondering if anyone successfully installed any driver side swivel, while keeping the 110v outlet.
You can keep the 120V if you built a new housing/bracket for it by the e brake.I don't see how. Pop the upper cover off the brake and then remove the lower. They both pull up to remove. There's just no room.
Honestly if I mounted it to the back of the battery box it would actually be more useful. Might have to go this route. Do you have any pictures of your invertor in the battery box area.You can keep the 120V if you built a new housing/bracket for it by the e brake.
Or you could relocate it to say behind the driver seat. I separated the 120V wiring from the E brake wiring and was able to move the inverter to the battery box under the seat then the outlet did reach to behind the seat pedestal. You could def mount it there but may not look that pretty.
I'm terrible at taking pictures when I'm in the middle of doing things. I have a few random pics but didn't take the time to document it very well and the images are low quality. I can go back and reinstall anytime but would have to remove the seat and swivel.....therefore likely not happening until I need a new battery.Honestly if I mounted it to the back of the battery box it would actually be more useful. Might have to go this route. Do you have any pictures of your invertor in the battery box area.
Did you have to trim the plastic trim for it to swivel?To further on this post I've installed the Amazing Auto swivels on a 2019 Transit with the 10 way power/heated seats.
Yes I needed to trim the plastic trim of both seats on the outer trim only. I trimmed approx 2" and need to raise the seat before swiveling.Did you have to trim the plastic trim for it to swivel?
