1 - 9 of 9 Posts
The wife and I are keeping an eye out for a Transit van to use for a camper conversion. If we can find something on a lot in California, we may jump on it.
I search dealer inventories and I can find the high roof 148" WB models but can't identify on the window stickers if they are the extended body or not.
Anyone know how to tell from the window sticker?
I am fairly certain that you can tell from the VIN.
For example: 1FTSW3XG4FKA04268
The 3X means it is a single wheel 350 extended. If it was 4X it would be dual rear wheel. If it was 2X it would be 250 extended.
It is odd that it is not otherwise mentioned on the sticker.
It would not matter if Ford's inventory search was more than barely useful.
I have been using car.com's inventory search lately. I think they have close to 10,000 Transits listed as inventory, so, while they may not be comprehensive, they are a good source - and you can search for "extended".
Actually you need to use the three characters of the body code.
The three existing "2X" codes: are for High Long vans or wagon.
See the Transit Body Decoder at:
http://transitbodydecoder.com/
You can use "12367" if you need a code to log in.
Don't know if this will help you. The columns don't line up with the top row.
Body Code Body Series Roof Height Wheelbase Inch Door GVWR Max. Payload Seating Capacity 3.7L Ti-VCT V6 (99M) 3.5L EcoBoost® V6 (99G) 3.2L I5 Diesel (99V)
E1C VAN 150 MED REG 130 SLIDING PASS 8,600 3,550 STANDARD OPTIONAL OPTIONAL
E1D VAN 150 MED REG 130 DUAL1 8,600 3,550 STANDARD OPTIONAL OPTIONAL
E1Y VAN 150 LOW REG 130 SLIDING PASS 8,600 3,680 STANDARD OPTIONAL OPTIONAL
E1Z VAN 150 LOW REG 130 60/40 8,600 3,680 STANDARD OPTIONAL OPTIONAL
E2C VAN 150 MED LONG 148 SLIDING PASS 8,600 3,400 STANDARD OPTIONAL OPTIONAL
E2D VAN 150 MED LONG 148 DUAL1 8,600 3,400 STANDARD OPTIONAL OPTIONAL
E2Y VAN 150 LOW LONG 148 SLIDING PASS 8,600 3,550 STANDARD OPTIONAL OPTIONAL
E9Z VAN 150 LOW LONG 148 60/40 8,600 3,550 STANDARD OPTIONAL OPTIONAL
F4U VAN 350 HD HIGH LONG-EL 148 EL DUAL1 9,950 4,150 N/A STANDARD OPTIONAL
F4X VAN 350 HD HIGH LONG-EL 148 EL SLIDING PASS 9,950 4,150 N/A STANDARD OPTIONAL
F6P CA 350 HD LOW REG 138 N/A 9,950 5,610 STANDARD N/A OPTIONAL
F6Z CC 350 HD LOW REG 138 N/A 9,950 5,610 STANDARD N/A OPTIONAL
F8P CA 350 HD LOW LONG 156 N/A 9,950 5,550 STANDARD N/A OPTIONAL
F8Z CC 350 HD LOW LONG 156 N/A 9,950 5,550 STANDARD N/A OPTIONAL
F9P CA 350 HD LOW LONG-EL 178 N/A 9,950 5,460 STANDARD N/A OPTIONAL
F9Z CC 350 HD LOW LONG-EL 178 N/A 9,950 5,460 STANDARD N/A OPTIONAL
K1Y WAGON 150 LOW REG 130 SLIDING PASS 8,550 2,900 8/10 STANDARD OPTIONAL N/A
K1Z WAGON 150 LOW REG 130 60/40 8,550 2,900 8/10 STANDARD OPTIONAL N/A
K1C WAGON 150 MED REG 130 SLIDING PASS 8,550 2,780 8/10 STANDARD OPTIONAL N/A
R1C VAN 250 MED REG 130 SLIDING PASS 9,000 3,950 STANDARD OPTIONAL OPTIONAL
R1D VAN 250 MED REG 130 DUAL1 9,000 3,950 STANDARD OPTIONAL OPTIONAL
R1Y VAN 250 LOW REG 130 SLIDING PASS 9,000 4,080 STANDARD OPTIONAL OPTIONAL
R1Z VAN 250 LOW REG 130 60/40 9,000 4,080 STANDARD OPTIONAL OPTIONAL
R2C VAN 250 MED LONG 148 SLIDING PASS 9,000 3,800 STANDARD OPTIONAL OPTIONAL
R2D VAN 250 MED LONG 148 DUAL1 9,000 3,800 STANDARD OPTIONAL OPTIONAL
R2U VAN 250 HIGH LONG 148 DUAL1 9,000 3,720 STANDARD OPTIONAL OPTIONAL
R2X VAN 250 HIGH LONG 148 SLIDING PASS 9,000 3,720 STANDARD OPTIONAL OPTIONAL
R2Y VAN 250 LOW LONG 148 SLIDING PASS 9,000 3,950 STANDARD OPTIONAL OPTIONAL
R2Z VAN 250 LOW LONG 148 60/40 9,000 3,950 STANDARD OPTIONAL OPTIONAL
R3U VAN 250 HIGH LONG-EL 148 EL DUAL1 9,000 3,510 STANDARD OPTIONAL OPTIONAL
R3X VAN 250 HIGH LONG-EL 148 EL SLIDING PASS 9,000 3,510 STANDARD OPTIONAL OPTIONAL
R5P CA 250 LOW REG 138 N/A 9,000 4,850 STANDARD N/A OPTIONAL
R5Z CC 250 LOW REG 138 N/A 9,000 4,820 STANDARD N/A OPTIONAL
R7P CA 250 LOW LONG 156 N/A 9,000 4,720 STANDARD N/A OPTIONAL
R7Z CC 250 LOW LONG 156 N/A 9,000 4,420 STANDARD N/A OPTIONAL
S4U VAN 350 HD HIGH LONG-EL 148 EL DUAL1 10,360 4,560 N/A STANDARD OPTIONAL
S4X VAN 350 HD HIGH LONG-EL 148 EL SLIDING PASS 10,360 4,560 N/A STANDARD OPTIONAL
S6P CA 350 HD LOW REG 138 N/A 10,360 6,020 STANDARD N/A OPTIONAL
S6Z CC 350 HD LOW REG 138 N/A 10,360 5,990 STANDARD N/A OPTIONAL
S8P CA 350 HD LOW LONG 156 N/A 10,360 5,960 STANDARD N/A OPTIONAL
S8Z CC 350 HD LOW LONG 156 N/A 10,360 5,890 STANDARD N/A OPTIONAL
S9P CA 350 HD LOW LONG-EL 178 N/A 10,360 5,870 STANDARD N/A OPTIONAL
S9Z CC 350 HD LOW LONG-EL 178 N/A 10,360 5,790 STANDARD N/A OPTIONAL
U4X WAGON 350 HD HIGH LONG-EL 148 EL SLIDING PASS 10,360 3,480 15 N/A STANDARD OPTIONAL
W2C VAN 350 MED LONG 148 SLIDING PASS 9,500 4,300 STANDARD OPTIONAL N/A
W2D VAN 350 MED LONG 148 DUAL1 9,500 4,300 STANDARD OPTIONAL N/A
W2U VAN 350 HIGH LONG 148 DUAL1 9,500 4,220 STANDARD OPTIONAL N/A
W2X VAN 350 HIGH LONG 148 SLIDING PASS 9,500 4,220 STANDARD OPTIONAL N/A
W2Y VAN 350 LOW LONG 148 SLIDING PASS 9,500 4,450 STANDARD OPTIONAL N/A
W2Z VAN 350 LOW LONG 148 60/40 9,500 4,450 STANDARD OPTIONAL N/A
W3U VAN 350 HIGH LONG-EL 148 EL DUAL1 9,500 4,010 STANDARD OPTIONAL OPTIONAL
W3X VAN 350 HIGH LONG-EL 148 EL SLIDING PASS 9,500 4,010 STANDARD OPTIONAL OPTIONAL
W7P CA 350 LOW LONG 156 N/A 9,500 5,290 STANDARD N/A OPTIONAL
W7Z CC 350 LOW LONG 156 N/A 9,500 5,220 STANDARD N/A OPTIONAL
X2C WAGON 350 MED LONG 148 SLIDING PASS 9,000-9,250 2,780 12/15 STANDARD OPTIONAL OPTIONAL
X2X WAGON 350 HIGH LONG 148 SLIDING PASS varies 2,690 12/15 STANDARD OPTIONAL OPTIONAL
X2Y WAGON 350 LOW LONG 148 SLIDING PASS 9,000-9,250 2,730 12/15 STANDARD OPTIONAL OPTIONAL
X2Z WAGON 350 LOW LONG 148 60/40 9,000-9,250 2,730 12/15 STANDARD OPTIONAL OPTIONAL
1 - 9 of 9 Posts
