I'm on the fence; the extra cost, and the availability were the reason I got the 3.7. It SEEMS like a pair of turbos vs no turbos would increase likelihood of breakdown. But again, I think it's all in how you drive it.
Ford is refining it's Ecoboost motors, but current specs for existing versions are as follows:
2.0 275hp, 280 torque (2017 Ford Edge, Escape)
2.3 280, 310 (Explorer) (310, 320 in the Mustang)
2.7 325, 375 (F150)
3.0 400, 400 (Lincoln MKZ)
3.5 310, 400 (Transit) (380, 460 Lincoln Navigator)
Compare this to the 3.7 Duratec in the Transit of 302, 278.
Fuel consumption based on displacement means that the 3.5 should get slightly better MPG than the 3.7. The specs are the reason I say the 2.0 should be offered instead of the 3.7. A very good motor might be the 2.7, used in the Fusion sport and the Lincoln Continental. A lot more power and should yield 30% better MPG, ie. 23-24mpg instead of 18. That also translates to 30% more range per tank, 520 instead of 400. (I seem to get almost exactly 100 miles per quarter tank on the 3.7 in mixed driving. 20.9 gallon tank)
It should be noted that Ford is phasing out the 3.7 in the coming years.
