How are you guys wiring up your house battery? I'm planning on wiring mine to my starter battery through a 60A relay triggered by the engine run signal. The CCM says that the engine run signal is on when in run or accessory, the latter seems incorrect. Seems like I don't want it on when I'm in accessory.
They have another lead which uses ground as a run signal which I think can pull the relay down, I may try to use that one instead. Any experience with this?
Any downside to using the run signal? I think accessory is wrong, I think I want both batteries isolated when I'm in accessory.
Which one are you guys using? I guess this is only relevant if you're using the alternator to charge, those using solar only need not respond you know who you are, though I may eventually go solar only at some point.
