Not sure this is the right forum for this but I need help.
Transit with 3x100 LiPo batteries, 240w solar was running at 100% charge almost constantly and then something happened & I don't know what.
Sequence of events:
I ran a couple small power tools off the inverter. Afterward, I checked the battery level & there was almost no impact. Great. A couple days later I was in the van again & saw that the charge was down to 89% & realized I'd left the inverter ON. Turned it off. Batteries started charging but stopped at 92%. Looked again next day, very sunny. 92%. Not charging. Each time though that the level dropped below 92, the batteries started charging but again stopping at 92%. I opened the power panel and saw that the Renogy DC-DC MPPT Charger indicated that it was charging a FLD type battery so the starter not the house.
There had been fires in the area where the van is so I thought maybe the panels were dirty. I sprayed them but that also did not seem to have an impact. I don't know if the panels aren't working/connected or if the Renogy DC-DC MPPT Charger is the problem.
I drove the van about 40 miles figuring that would boost the starter and maybe get the charger refocused on the house batteries. No change.
So I'm in Italy for a couple months & I figured the van would keep doing the 92% thing since there was plenty of sun most of the time. I had a friend check and it's down to 8%! Even after plugging into the 110 circuit over night.
Any thoughts, advice, etc.?
Thanks in advance. Dylan
Sequence of events:
